Posted: 2024-11-14 07:20 AM
In my 60 KVA UPS, input voltage is 422, 426,433 volt, On display shown same but on UPS display bypass voltage showing 434, 458 and 453 volt and may be due to it alarm pop up bypass voltage out of tolerance and Bypass out of sync. What may be issue? What should be solution?
Posted: 2025-02-05 03:02 AM
It seems the unit is Easy 3M 60 KVA,we suggest to check the input voltage and frequency of mains then verify the below settings :
Min. bypass RMS voltage (V) default value is -10V you can expand it to -15 V
Max. bypass RMS voltage (V)default value is 10V you can expand it to 15V
Bypass frequency range (%) default value is 10
Output slew rate (Hz/sec) is 0.5 Hz/s
The permissible three-phase voltage
- limit range is: -30%*Vnor ~ +25%*Vnor, the default range is -10%*Vnor~ +10%*Vnor (output voltage 400Vac)
for the frequency
Range is +/-10% (hysteresis :0.2Hz).
If all the setting are ok,then the bypass SCRs needs to be verified and check they are not shorted, if yes the SCR KIT needs to be replaced if it is all ok,then replace the SCR driver board ,if the issue the same replace CT board and check if the readings are showing correct ,if the issue then control boards would required to be replaced
an SR is required to come onsite and verify the issue and check the logs for investigation
Karim
for the frequency
Karim
