Posted: 2021-07-07 10:43 PM . Last Modified: 2024-03-01 12:28 AM
I am installing new UPS with 4 XLPB there is rbc1 and rbc2 but each one XLBP give error only rbc1 disconnected.
i tryed alarm test disconnect reconnect and run on UPS with no input power.
thank you.
I asked someone about this as I was not sure. From what I understand, you've already tried to physically re-connect the internal batteries in the XLBP? If so, make sure that you have 500 watts of load or more and run a self test again. RBC's in batt packs are often not recognized without load.
If that doesn't help or change the situation, I suggest that you please contact your local technical support office as there may be a problem like a blown fuse and it may require spare parts to be sent to you which local support can handle and manage.
