New APC Back UPS Pro 1500 - F02 error
  • New APC Back UPS Pro 1500 - F02 error
2151
Spock Teken
101
83
Posted: ‎2021-06-29 08:01 AM . Last Modified: ‎2024-03-21 04:27 AM
40107
Our new APC Back UPS Pro 1500 (4 days old) has started to show the F02 error every time it is switched on. Looking through the forums this is not an isolated problem and it appears that there is a problem with this range.
We've tried the "brain dead" technqiue to clear the memory as noted elsewhere on the forum several times but now the unit won't switch on at all - just F02 and loud beeping. So after much cable re-arrangement and angst over the last few hours, the old set up and surge protection is back in place :o( - not happy as you can imagine. We did a lot of research on various UPS units and settled on APC as the best supplier - but unfortunately we missed the dreaded F02 issue.
We purchased the unit from a UK supplier but ideally we'd like APC to sort this out directly. How do we progress sorting this out please?
Dave
1
40078
you can try turning on the equipment, without the battery, wait 2-3 minutres, turn off and then reconnect the battery and see if the problem persist, the lcd equipment, most of the time, i have fixed them using that troubleshooting process
  • back ups
Replies 5
We would recommend you work with tech support for you region. They can walk you through any additional troubleshooting steps(if necessary) and will RMA a new back up(if necessary)
1
40079
  • back ups
Mar
Mar
Cadet
Posted: ‎2024-01-24 11:02 AM
APC Back-UPS Pro 10-outlet
I bought this product, but in less than a month I noticed that the battery is not charging at all, It takes time for me to contact customer service but no avail. I tried to contact office depot where I bought this item but they said its not their concern anymore. I tried to contact this company and they assist me to remove and put back the battery, but still battery is not charging at all and the person I emailed, he never reply back.
Mar
Mar
Cadet
Posted: ‎2024-01-25 05:09 AM
In response to BillP
I did that already but still the same problem.
G-Rega
G-Rega
Cadet
Posted: ‎2025-01-14 08:37 AM
Have quite the same problem, but the UPS is out of warranty. Opened it up, but nothing seem burnt. Changed the battery from another same UPS, but nothing helped. Where to look for the problem seems many people have? It is not a cheap device. Any known service shop in Slovenia?
This is a heading
