Room layout toolbar
Working with the room layout
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Working in the ITA desktop client
  • Working with the room layout
  • Room layout toolbar
  • Mark as Read
  • What does the power tool tip tell me
  • What does the cooling tool tip tell me
  • Room overlays
  • Power tool tip troubleshooting
  • Inventory report
  • Exporting layout as image
  • Room overlays
  • Inventory report
EcoStruxure IT Support
Request Support
Back to Working with the room layout
  • Mark as Read
Room layout toolbar
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
Default Tools
Description
Zooms in (Ctrl+).
Zooms out (Ctrl-).
Zooms to show full layout (Ctrl+Home).
Toggles rack layout to show or hide the rack layout next to the floor layout.
Exports layout as image file.
Toggles room design mode to show or hide the room design icons.
Enables default pointer cursor.
Enables marquee select cursor to multi-select by dragging a box around a selection.
Enables ruler cursor to drag a line to show a distance, for example to other equipment or a wall.
Room Design Tools
Description
Enables resize cursor to resize room elements, such as rows, blocks, gaps, containment systems and walls.
Enables the add corner cursor to add corner dots for creating new walls. To create a new wall, subsequently use the resize cursor to drag the new piece of wall between the dots into position.
Enables the pan tile cursor to change the starting point of the tile layout.
102237511_360037995374.png102237511_360037995374.png Enables the draw wall tool to create walls and split cages. Press and hold Shift to draw consecutive wall segments.
102237515_360037995374.png102237515_360037995374.png Enables the draw rectangular shape tool. Double-click a shape to create a cage.
Generates a row layout with the settings selected in the wizard.
102237434_360037995374.png102237434_360037995374.png Resets to default layout in the Power Path Layout.
102237431_360037995374.png102237431_360037995374.png Paint items that are connected to equipment in other rooms as solid in the Power Path Layout.
Rack Design
Tools
Description
102237434_360037995374.png102237434_360037995374.png Enables the show network tool to show network connections in the rack view.
102237431_360037995374.png102237431_360037995374.png Enables the hide network tool to hide network connections in the rack view.
102237458_360037995374.png102237458_360037995374.png Enables the connection tool to create network connections by clicking the source and then the destination of the network connection.
