What does the cooling tool tip tell me
Working with the room layout
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Working in the ITA desktop client
  • Working with the room layout
  • What does the cooling tool tip tell me
  • Mark as Read
  • What does the power tool tip tell me
  • Room overlays
  • Room layout toolbar
  • Power tool tip troubleshooting
  • Inventory report
  • Exporting layout as image
  • Room overlays
  • Inventory report
EcoStruxure IT Support
Request Support
Back to Working with the room layout
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
Cooler supply temperature
Cooler supply temperature is a function of cooler capacity and its control algorithm; however, it can be written generally as a function of cooler return temperature and cooler airflow rate.
The tool tip appears in the Cooling view when hovering over a cooling unit in the layout.
Cooler return temperature
Cooler return temperature is the result of the mixing of streams which originate at rack exhausts or from the ambient.
Rack inlet temperature
Rack inlet temperature is the result of the mixing of streams which originate at each cooler source or from the ambient.
The tool tip appears in the Cooling view when hovering over a rack in the layout.
