Download the EcoStruxure IT Gateway
What's new in EcoStruxure IT Gateway
Get the latest news, release notes, and other need-to-know information about EcoStruxure IT Gateway
Select a Country
  • EcoStruxure IT Help Center
  • Gateway
  • What's new in EcoStruxure IT Gateway
  • Download the EcoStruxure IT Gateway
  • Mark as Read
  • EcoStruxure IT Gateway 2.2.0 release notes
  • Installing Gateway 2.1.1 and newer on Windows requ...
  • EcoStruxure IT Gateway known issues
  • EcoStruxure IT Gateway device library release note...
  • EcoStruxure IT Gateway 2.1.x release notes
  • EcoStruxure IT Gateway 2.0 release notes
  • Installing EcoStruxure IT Gateway on Windows 11 24...
EcoStruxure IT Support
Request Support
Back to What's new in EcoStruxure IT Gateway
  • Mark as Read
JLehr Champion
‎2024-02-29 01:44 AM
EcoStruxure IT Gateway version 2.2.0.16
May 2026
If your Gateway version is older than 1.18, contact support for assistance.
In June 2025, Microsoft introduced a new certificate signing authority in Windows operating system updates.  This certificate must be installed on your Windows computer to install EcoStruxure IT Gateway.
To get the new root certificate, update Windows to the latest version.
Installing EcoStruxure IT Gateway on Windows requires the new certificate in recent Windows updates
Make sure your operating system is up to date and patched regularly.
Windows users may see a message from Windows Defender that EcoStruxure IT Gateway is an unrecognized application. Microsoft addressed this issue in a recent update.
Be sure to check system requirements to avoid any connection issues.
Detailed instructions for Installing and setting up EcoStruxure IT Gateway
Release notes
Download Gateway for Windows
Download EcoStruxure IT Gateway for WindowsDownload EcoStruxure IT Gateway for Windows
Windows
SHA1 checksum:
38cfeba968c239f3ef852287792aaf7bba17694d
Download Gateway for Linux
 Download EcoStruxure IT Gateway for LinuxDownload EcoStruxure IT Gateway for Linux
Linux
SHA1 checksum:
02451d0b31e9e5a503ce24624f1985b2a5a2de62
 How to verify the Gateway checksum
Install the Gateway.
After you download the gateway software, reference the installation guides.
     video icon 50.png   Installing the EcoStruxure IT Gateway on Windows
     video icon 50.png   Installing the EcoStruxure IT Gateway on Linux
Log in to the Gateway.
After you download and install the Gateway, go to the default address https://<server name or IP address> and set the password for the system administrator. The default username is admin.
Configure device credentials.
Create device credential settings for discovery and polling SNMPv1, SNMPv3, NetBotz, and Redfish devices.
You can reuse these credentials for all your device discoveries and add additional credentials as needed.
Create file transfer settings for device configuration, firmware update, NetBotz 75x video clips, and other EcoStruxure IT features to function properly.
Discover devices
Enter an IP address or IP address range, or import an IP address list to easily discover devices.
Having trouble discovering devices? Get help here!
Register and connect the Gateway.
Click Register Gateway and connect your Gateway to your EcoStruxure IT organization.
84% helpful (5/6)
