Export Clip
Surveillance
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • Surveillance
  • Export Clip
  • Mark as Read
  • Surveillance feature
  • Surveillance deployments and Data Center Expert se...
  • Surveillance perspective
  • Thumbnails view
  • Button icons (Thumbnails view)
  • Sort Surveillance Thumbnails display
  • Camera view
  • NetBotz Appliance Camera Settings option
  • Using post mode
  • Surveillance clips
  • Surveillance Settings options
  • Surveillance access
  • Licensing Surveillance and cameras
  • General Surveillance Settings
  • Surveillance Activation Settings
  • Export Clip
  • Surveillance scheduling
  • Server Settings
  • Thumbnails view
  • Camera view
  • Using post mode
  • Export Clip
  • Server Settings
EcoStruxure IT Support
Request Support
Back to Surveillance
  • Mark as Read
Export Clip
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Export the selected clip in an MPEG-1, AVI, Signed AVI (if the digital signature option is enabled), Current Image, or Audio format.
Note
Access the "Export Clip" display from the "Clip Viewer" display, or from the Clip option in the "View Alarm Details" display available for the Active Alarms and Alarm History views, using the Export Clip icon (92307570_360038793174.png92307570_360038793174.png).
Element Description
Data Format
Use to select the desired format as the output type.
  • MPEG-1
    Note
    Disabled when a clip consists of a single frame.
  • AVI
  • Signed AVI (see below)
  • Current Image
  • Audio
The Signed AVI format is only available if the clip was captured by a camera with the Generate digital signature option in the "Surveillance Settings" display enabled.
Note: The Signed AVI option is only available if the NetBotz Appliance has the optional Premium Software Module installed.
If the Current Image option is selected, the currently displayed frame will be saved as a JPG file.
When clips are recorded, the images and audio are saved as separate files. Therefore, an exported clip cannot contain both image and audio data. The audio can be saved to a separate file by selecting the Audio option.
Note: If a clip contains audio data, but the audio capture option on the remote device was not activated, only white noise will be recorded.
Filename Use to set the location and the filename of the exported clip.
