sending object log by object address or name via email
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • sending object log by object address or name via email
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-10-03 02:57 AM . Last Modified: ‎2024-07-14 11:47 PM
3078
hello every one
I found this function script in the community that receives the log hours and the email addresses, and it will send the logged objects by email.
I want the function script to send only the logged data for a specific object address.
script:  "
  ------------------------BEGINNING OF CSV CREATING-------------------------------
  logtime = os.time() - 60 * 60 * log_hrs
-- list of objects by id
objects = {}
-- objects with logging enabled
query = 'SELECT address, datatype, name FROM objects WHERE disablelog=0'
for _, object in ipairs(db:getall(query)) do
  objects[ tonumber(object.address) ] = {
    datatype = tonumber(object.datatype),
    name = tostring(object.name or ''),
end
--log("objects",objects)
-- csv buffer
  buffer = {'sep=,'..'\r\n'.. '"date","address","name","value"' }
-- get object logs
query = 'SELECT src, address, datahex, logtime, eventtype FROM objectlog WHERE logtime >= ? ORDER BY id DESC'
--log(query, logtime)
for _, row in ipairs(db:getall(query, logtime)) do
  object = objects[ tonumber(row.address) ]
  --log("object " .. _, object)
  -- found matching object and event type is group write
  if object and row.eventtype == 'write' then
    datatype = object.datatype
    -- check that object datatype is set
    if datatype then
      -- decode data
      data = knxdatatype.decode(row.datahex, datatype)
      -- remove null chars from char/string datatype
      if datatype == dt.char or datatype == dt.string then
        data = data:gsub('%z+', '')
      -- date to DD.MM.YYYY
      elseif datatype == dt.date then
        data = string.format('%.2d.%.2d.%.2d', data.day, data.month, data.year)
      -- time to HH:MM:SS
      elseif datatype == dt.time then
        data = string.format('%.2d:%.2d:%.2d', data.hour, data.minute, data.second)
      end
    else
      data = ''
    end
    -- format csv row
    logdate = os.date('%Y.%m.%d %H:%M:%S', row.logtime)
    csv = string.format('%q,%q,%q,%q', logdate, knxlib.decodega(row.address), object.name, tostring(data))
    -- add to buffer
    table.insert(buffer, csv)
  end
end
  -------------------------END OF CSV CREATING----------------------------
this is the community link:  https://community.se.com/t5/KNX-Forum/HomeLynk-sending-object-log-via-email/td-p/51550
@Erwin-vd-Zwart
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Scripts
  • SpaceLYnk
Erwin-vd-Zwart
Janeway
Posted: ‎2020-10-04 02:55 PM
25
3060
Yes, sorry for the mistake but the address is encoded in the DB so you need an extra command (:
Change:
db:getall(query, "1/1/1", logtime)
into:
db:getall(query, knxlib.encodega("1/1/1"), logtime)
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-04 12:16 AM
3010
Try this:
1) Add a unique TAG to your objects of interest you want to show in your logs view, in this sample i used 'logs'
1) Run code below once to automatically create the logs.lp file in the user FTP folder, after that you can deleted this code.
3) To test this .lp file open your browser and open http://192.168.0.10/user/logs.lp?tag=logs
4) Create a frame with the URL /user/logs.lp?tag=logs  or  /user/logs.lp?tag=logs&limit=10 to limit the number of logged items for each object.
-- Run this code once and use with url: /user/logs.lp?tag=logs or when to limit each log with less then 100 results use: /user/logs.lp?tag=logs&limit=10
dst = '/www/user/logs.lp'
io.writefile(dst, [[
require('apps')
tagname = getvar('tag') or ''
limit = getvar('limit') or 100
objects = grp.tag(tagname)
logitems = {}
for _, obj in ipairs(objects) do
query = 'SELECT * FROM objectlog WHERE address=? ORDER BY id DESC LIMIT ?'
items = db:getall(query, obj.id, limit)
for _, item in ipairs(items) do
logtime = os.date('%c', item.logtime)
value = busdatatype.decode(item.datahex, obj.datatype)
if item.src > 0 then
src=buslib.decodeia(item.src)
else
src='local'
end
table.insert(logitems, {name = obj.name, datetime = logtime, value = value, src=src, eventtype = item.eventtype})
end
end
if #logitems == 0 then
print('no data found from objects with this tag in the object logs')
return
end
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<title>Logs</title>
<link rel="stylesheet" href="/apps/css/bootstrap.css">
<style>
.table { table-layout: fixed; }
.name { width: 60%; }
.value { width: 20%; }
.datetime { width: 20%; }
/* .source { width: 20%; } */
/* .event { width: 20%; } */
</style>
</head>
<body>
<table class="table">
<tr>
<th class="name">Name</th>
<th class="value">Value</th>
<th class="datetime">Date/time</th>
<!-- <th class="source">Source</th> -->
<!-- <th class="event">Event type</th> -->
</tr>
for _, item in ipairs(logitems) do
<tr>
<td><?=escape(item.name)?></td>
<td><?=escape(item.value)?></td>
<td><?=escape(item.datetime)?></td>
<!-- <td><?=escape(item.src)?></td> -->
<!-- <td><?=escape(item.eventtype)?></td> -->
</tr>
<? end ?>
</table>
<script type="text/javascript">
</script>
</body>
</html>
script.disable(_SCRIPTNAME)
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-04 01:53 PM
8
2987
Every customer wants custom development for their special needs, We can’t support all off that (:
I can provide info on how to build your own app but it requires quite some knowledge of HTML, CSS, JS, SQL queries and LUA.
Replies 28
Erwin-vd-Zwart
Janeway
Posted: ‎2020-10-03 03:38 AM . Last Modified: ‎2020-10-03 03:41 AM
3075
You just need to change the query in that case:
-- get object logs
query = 'SELECT src, address, datahex, logtime, eventtype FROM objectlog WHERE address = ? AND logtime >= ? ORDER BY id DESC'
for _, row in ipairs(db:getall(query, "1/1/1", logtime)) do
In this query only object 1/1/1 is selected
BR,
Erwin
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-10-04 01:36 AM
3070
hank you @Erwin-vd-Zwart  for your reply
I tried that but I receive an empty CSV file.
is there anything else that should be changed?
Best Regards,
Erwin-vd-Zwart
Janeway
25
3061
Change:
into:
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-10-05 01:03 AM
3055
thank you @Erwin-vd-Zwart  I appreciate your time.
with your permission, I need one last thing:
how to send in the same CSV file multiple sheets.
I have three objects logged and I want to send one CSV file containing three sheets for each object log.
regards,
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2020-10-05 03:35 AM
23
3047
CSV does not support multiple sheets, that is a Excel functionality..
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-10-05 06:08 AM
22
3045
thanks @Erwin-vd-Zwart
appreciate your help
Best Regards,
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-02 10:05 AM
3024
Hi @Erwin-vd-Zwart  I hope you are doing well
I want to show some of the objects log values in the visualisation, but I am lost in this code.
Could you tell me how to deal with object log values using lua script.
Regards
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-02 01:30 PM
20
3020
Well basically we do 2 query’s on the SQLite DB because the object log table holds only the records for the encoded GA, timestamp and value, so to get the name and other parameter we do the second request to map both together..
To help you better it would be good if you can elaborate a bit in what you try to achieve..
i also have a .lp code (client side lua in HTML) so you can create an app view for the object logs so you can embed the view by a frame into the visu after adding the .lp just need to add /user/logs.lp as URL in the frame to show them.
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-02 08:12 PM
3017
Hi @Erwin-vd-Zwart  I want to show daily/monthly energy which saved in the object logs.
I think what you say about .ip code will be a good solution, and its interesting.
Regard,
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-03 05:48 AM
3014
I can prepare something, but do you need to filter certain objects from the log, or just show all that is available in the list?
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-03 07:20 AM
3012
thank you @Erwin-vd-Zwart  for your response and effort
yah I want to filter certain objects.
regards,
Best Regards,
Erwin-vd-Zwart
Janeway
3011
Try this:
require('apps')
logitems = {}
else
src='local'
end
end
end
return
end
<!DOCTYPE html>
<html lang="en">
<head>
<title>Logs</title>
<style>
</style>
</head>
<body>
<tr>
</tr>
<tr>
</tr>
<? end ?>
</table>
</script>
</body>
</html>
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-04 11:22 AM . Last Modified: ‎2021-01-04 11:25 AM
3004
Thank you @Erwin-vd-Zwart  i appreciate your time and effort.
Amaizing its work greate
I have the following questions:
1- if i want to add more objects i will add tag to this object snd rerun the code again, this will not make any issue?
2- could I make the limit value as variable GA in the visu and the user change it.
3- also is it possible to let the user choose the objects he want to show?
3- the limit value shouldn't exceed 100?
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-04 11:59 AM . Last Modified: ‎2021-01-04 12:04 PM
10
2998
1- Just add the tag 'logs' at multiple objects, no need to run the .lp creation code again as that won't change the .lp file..
2- Yes it could but that would require a change in the code of the .lp file and re-run it once.
3- Yes can be made, but this is next level (kinda goes to an app level as you need a html selection box with JS code)
4- Yes can be exeeded, when the argument &limit= is missing the value 100 is used as a default but you can set it in any value as it's only used in the SQL query as limit of fetching items from the DB.
For item 2 change the start of the .lp creation code like this and run once again:
-- Use with URL /user/logs/lp?tag=logs
limitaddr = '1/1/1' -- use a 1, 2 or 4 byte integer object for this
require('apps')
limit = grp.getvalue(limitaddr) or 100
.... rest of the code unchanged
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-04 12:53 PM . Last Modified: ‎2021-01-04 01:05 PM
2994
Thank you @Erwin-vd-Zwart  for your response.
Regarding point 3 it will be a better solution for the end user.
I will be waiting for that 🙂
Appreciate your time and effort.
Best Regards,
Erwin-vd-Zwart
Janeway
8
2988
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-04 07:19 PM . Last Modified: ‎2021-01-04 08:16 PM
Oh really
I didn't think it will be in this complexity.
For me this is a new way of showing data, Could you tell me where I can use this method in the SL. This is my last question 🤣
I know that I am asking a lot but I like to learn from experts, and not always you got this chance  ☺️
thanks for your support @Erwin-vd-Zwart .
Hope you a good life .
Best Regards,
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-05 12:22 AM
2972
Hello @Erwin-vd-Zwart
I tried to use GA for the limit but I got This:
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-05 12:31 AM
2969
Are you using /user/logs/lp?tag=logs
must be /user/logs.lp?tag=logs
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-05 12:41 AM
2967
I try this: /user/logs.lp?tag=logs
I got data but the limit didn't change!
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-05 01:49 AM
The limit is per object that is tagged, so if you have 3 objects tagged and set the limit to 10 you get 3 times the limit of 10 so 30 lines, try to reduce the limit if you have a lot of tagged objects
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-05 01:51 AM
2962
Hi @Erwin-vd-Zwart
is there any thing in the limit?
I try an easy way for the list by adding and removing TAG using script 🙂
and it works fine but should refresh to view the changes.
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-05 02:42 AM
5
2958
In the .lp creation code below i added a listener on the limit object, if the value is changing i reload the document
-- Use with URL /user/logs.lp?tag=logs
require('apps')
limitaddr = '5/0/3' -- use a 1, 2 or 4 byte integer object for this
logitems = {}
else
src='local'
end
end
end
if logitems == nil or #logitems == 0 then
return
end
<!DOCTYPE html>
<html lang="en">
<head>
<title>Logs</title>
  <script src="/apps/js/jquery.js.gz"></script>
  <script src="/apps/js/localbus.js.gz"></script>
  <script src="/scada/vis/busdecode.js.gz"></script>
<style>
</style>
</head>
<body>
<tr>
</tr>
<tr>
</tr>
<? end ?>
</table>
var limitaddr = <? print('"' .. limitaddr .. '"') ?>;
var startlimit = <? print(limit) ?>;
localbus.init();
// listen to a single object
localbus.listen('object', limitaddr, function(value) {
if (value != startlimit){
startlimit = value;
location.reload();
}, true);
</script>
</body>
</html>
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-05 03:03 AM
2956
Great Jop @Erwin-vd-Zwart
Many thanks 🙂
Best Regards,
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-05 03:10 AM
2953
@Erwin-vd-Zwart  How Can I add another listener, I want to use it to reload the document when the TAG List changed
regards,
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-05 03:11 AM
Make sure to set the min setting (in the vis params of the object) of the limit object to 1 (otherwise with 0 there are no values fetched and loading discarded)
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-05 03:17 AM
1
2948
You can solve that server side, add this add the end of your TAG adding script:
limitobject = '1/1/1'
limitvalue = grp.getvalue(limitobject)
grp.write(limitobject, limitvalue+1)  -- increase value with 1 to trigger the refresh
grp.write(limitobject, limitvalue) -- write original limit value back
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-05 03:24 AM
@Erwin-vd-Zwart  I don't know how to thank you.
Many thanks 🙂
regards,
Best Regards,
