HomeLynk: sending object log via email
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • HomeLynk: sending object log via email
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Koen_Rowies
Lt. Commander Koen_Rowies Lt. Commander
Lt. Commander
Posted: ‎2015-01-28 06:11 AM . Last Modified: ‎2024-07-15 12:03 AM
4
1060
We have a customer who ask if it's possible to get the object log from HL via email once a day.
I have been testing with a script that sends every hour a .csv of the last hour events to an ftp and that works fine. But now i would like to let it send the .csv by mail using a gmail account. Is there someone who did this already or could help me with modifying this script?
Koen
script:
require('socket.ftp')
-- ftp file
ftpfile = string.format('ftp://ftp:ftp123@192.168.0.10/%s.csv', os.date('%Y-%m-%d_%H-%M'))
-- get past hour data (3600 seconds)
logtime = os.time() - 60 * 60
-- list of objects by id
objects = {}
-- objects with logging enabled
query = 'SELECT address, datatype, name FROM objects WHERE disablelog=0'
for _, object in ipairs(db:getall(query)) do
  objects[ tonumber(object.address) ] = {
    datatype = tonumber(object.datatype),
    name = tostring(object.name or ''),
end
-- csv buffer
buffer = { '"date","address","name","value"' }
-- get object logs
query = 'SELECT src, address, datahex, logtime, eventtype FROM objectlog WHERE logtime >= ? ORDER BY id DESC'
for _, row in ipairs(db:getall(query, logtime)) do
  object = objects[ tonumber(row.address) ]
  -- found matching object and event type is group write
  if object and row.eventtype == 'write' then
    datatype = object.datatype
    -- check that object datatype is set
    if datatype then
      -- decode data
      data = knxdatatype.decode(row.datahex, datatype)
      -- remove null chars from char/string datatype
      if datatype == dt.char or datatype == dt.string then
        data = data:gsub('%z+', '')
      -- date to DD.MM.YYYY
      elseif datatype == dt.date then
        data = string.format('%.2d.%.2d.%.2d', data.day, data.month, data.year)
      -- time to HH:MM:SS
      elseif datatype == dt.time then
        data = string.format('%.2d:%.2d:%.2d', data.hour, data.minute, data.second)
      end
    else
      data = ''
    end
    -- format csv row
    logdate = os.date('%Y.%m.%d %H:%M:%S', row.logtime)
    csv = string.format('%q,%q,%q,%q', logdate, knxlib.decodega(row.address), object.name, tostring(data))
    -- add to buffer
    table.insert(buffer, csv)
  end
end
-- upload to ftp only when there's data in buffer
if #buffer > 1 then
  result, err = socket.ftp.put(ftpfile, table.concat(buffer, '\r\n'))
end
-- error while uploading
if err then
  alert('FTP upload error: %s', tostring(err))
end
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
sesa299442
sesa299442 Schneider Alumni (Retired)
Posted: ‎2015-01-28 07:21 AM
996
you can use this example function enclosed. I composed it together of some other examples 🙂
You just need to set the parameters in User editable area of the function.
Then you can call the function with two parameters:
- to: destination address
- log_hrs: number of hours you want to display in the csv (backwards from now)
The problem is that there is some problem with LuaSocket library in homeLYnk version 1.2.1.
Please run this script once in order to install library update:
os.execute('opkg --force-depends install http://dl.openrb.com/pkg/luasocket_2.0.2-7_mxs.ipk'))
If you cannot access internet from your homeLYnk, set proxy IP in the command (bold):
os.execute('export http_proxy=http://1.1.1.1:8080/ opkg --force-depends install http://dl.openrb.com/pkg/luasocket_2.0.2-7_mxs.ipk'))
Regards
Tomas
ObjectLog_CSV_email.txt.zip
Replies 4
lfiat
lfiat Schneider Alumni (Retired)
Posted: ‎2015-01-28 06:55 AM
996
Hello Koen,
I propose to use Application for homeLYnk about how to send a email with homeLynk
AN_Email, SMS and FTP in homeLYnk
I suggest you not to send a csv file but the text of your current csv file as the mail content: I don't believe at moment with homeLYnk mail LUA library it is possible to send a file attached in a mail.
Lionel
vaca
vaca Schneider Alumni (Retired)
Posted: ‎2015-01-28 07:06 AM
996
Hi Lionel and Koen,
it is possible to send a file directly without a need of storing it somewhere and actually it is not so complicated.
Just contact this guy , he was solving this issue with me a week or two ago. For sure I will inform him about your question here.
sesa299442
997
Regards
Tomas
Koen_Rowies
Lt. Commander
Posted: ‎2015-02-02 05:24 AM
Hello Tomas,
Works perfect from the first test!
Thanks!
5653
