count down timer as a function
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • count down timer as a function
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-12 07:34 AM . Last Modified: ‎2024-07-14 11:47 PM
1553
hello
I have multiple AC units, I want to add a timer for each one to turn off the AC with remain time and reset.
in order not to repeat the same script multiple times I think the function will be more optimized.
Is there any example of this using function?
regards,
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Scripts
  • SpaceLYnk
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-12 09:44 AM
7
1542
You could try this:
User library called user.timer:
function settimer(addr, ena, res, rem, time, event, scriptname)
if event.dst == res and grp.getvalue(res) == false then
return
end
tpid = storage.get('PID:' .. scriptname)
if tpid == nil then
pid = os.getpid()
storage.set('PID:' .. scriptname, pid)
else
pid = os.getpid()
os.kill(tpid, signal.SIGKILL)
end
if grp.getvalue(ena) == false then
storage.delete('PID:' .. scriptname)
grp.write(rem, 0)
grp.write(addr, false)
return
end
grp.write(addr, true)
for i = 0, time - 1, 1 do
grp.write(rem, time - i)
os.sleep(60)
end
grp.write(rem, 0)
end
Event based script triggered by tag on the enable and reset object
require('user.timer')
output = '6/0/0' ' -- bit object NO TAG !!
enable = '6/0/1' -- bit object with TAG to trigger this script
reset = '6/0/2' -- bit object with TAG to trigger this script
remaining = '6/0/3' -- byte object
delay = 10 -- in minutes
settimer(output, enable, reset, remaining, delay, event, _SCRIPTNAME)
Replies 10
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-12 07:51 AM
1548
What do you want to achieve with it?
When running a function from an event you load the same code as when running separate scripts, as events do run in parallel
From performance point of view you won’t gain anything...
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-12 08:11 AM
1545
hello @Erwin-vd-Zwart
I liked the function Just to make the script shorter instead of repeating the same code multiple times.
the idea is to let the user:
- set a timer to turn off the AC unit, we have around 20 units.
- Enable disable the timer
- reset the timer
- remain time
the user still could turn off the AC from Vis or by leaving seen.
Best Regards,
Erwin-vd-Zwart
Janeway
7
1543
You could try this:
return
end
if tpid == nil then
pid = os.getpid()
else
pid = os.getpid()
end
grp.write(rem, 0)
return
end
os.sleep(60)
end
grp.write(rem, 0)
end
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-13 02:37 AM
1532
I got this error:
User script:1: module 'user.timer' not found:
 no field package.preload['user.timer']
 no file './user/timer'
 no file 'Library user/timer'
 no file 'User library timer'
 no file 'Library user/timer.so'
 no file 'Library user.so'
stack traceback:
 [C]: in function 'require'
 User script:1: in main chunk
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-13 02:45 AM
1530
Did you create the userlib 'timer' with the corresponding function?
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-13 02:52 AM
1528
Sorry for that,
No, I add it to an old user lib.
many thanks
regards,
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-13 02:59 AM
3
1525
You can add the function settimer() to another user lib, or even common functions but in that case you need to adjust require('user.timer') to the other user lib name or when adding settimer to common functions you can remove the require() completely
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-14 12:47 AM
1521
thank you for the great support.
is this the correct (optimal) way to convert the remaining time to hh:mm format?
local remain = time - i
grp.update(rem, string.format("%02.f", math.floor(math.abs(remain)/60) )..':'..string.format("%02.f", math.fmod(math.abs(remain), 60) ) )
regards,
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-14 12:55 AM
1
1519
Short version: grp.update(rem, os.date('!%H:%M', remain * 60))
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-01-14 01:01 AM
great @Erwin-vd-Zwart
very short 🙂
Best Regards,
