Share Your Feedback โ€“ Help Us Improve Search on Community!
MTN6005-0001 Humidity value datatypepoint in KNX
SpaceLogic KNX Forum
Showing results forย
Did you mean:ย
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • MTN6005-0001 Humidity value datatypepoint in KNX
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dรถlger
Commander Heribert_Dรถlger Commander
31
SpaceLogic KNX - 4สบ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Henk
Crewman Henk
Crewman
Posted: โ€Ž2021-01-21 01:08 AM . Last Modified: โ€Ž2024-07-14 11:47 PM
3
929
Hi all,
I have a CO2, Humidity and temperature sensor in my house and I would like to send object 1 (Relative humidity value) to the Multitouch pro system (object 49) in the same room.
The problem is that the dtp length is 1 byte (5.*) and the Multitouch pro system wants to receive 2 byte (9.007).
For now I convert the object from the humidity sensor in a LUA script so that the correct value can be displayed on the Multitouch but I'm sure this is not the correct way to do things.
Is there an update for the MTN6005-0001 so that object 1 can hold 2 bytes instead of 1?
Thanks.
  • Thumbnail of SpaceLogic KNX - 4สบ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Tags (3)
  • ets
  • wiser for knx
Thomas_Rohde
Sisko
Posted: โ€Ž2021-01-27 02:47 AM
Hi Henk,
to "Is converting the values in LUA script the only solution to overcome this?
Or are there other solutions in which no LUA script is needed."
Unfortunately it is currently the only way to realize it.
to "Another question, I'm missing a lot of data types in Wiser, only the most common data types are present.
Is there an option to add data types in Wiser?"
Currently not but I guess it will be improved with upcoming versions more and more.
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Posted: โ€Ž2021-01-21 11:30 PM
911
Hello Henk,
unfortunately there is no update available ๐Ÿ˜ž
Kind regards
Thomas
Henk
Crewman Henk
Crewman
Posted: โ€Ž2021-01-27 02:26 AM
899
Hi Thomas,
Thanks.
Thomas_Rohde
Sisko
Hi Henk,
Kind regards
Thomas
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
