Converting time in ASCII String Format in to integer
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Converting time in ASCII String Format in to integer
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-12-20 07:11 AM . Last Modified: ‎2024-07-14 11:47 PM
1177
hello
I want to convert a time object ( datatype: ASCII String) into an integer
to compare it with the current time.
I tried to use string.format and string.gmatch but I get an error in the error log.
if there are some examples or ideas.
@Erwin-vd-Zwart
best regards,
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Scripts
  • SpaceLYnk
Erwin-vd-Zwart
Janeway
Posted: ‎2020-12-20 07:36 AM . Last Modified: ‎2020-12-20 07:37 AM
1168
Then string.split(value,':') is your friend (:
splitted = string.split(event.getvalue(),':')
hour = tonumber(splitted[1])
minute = tonumber(splitted[2])
log(hour,minute)
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-12-20 07:45 AM
1159
Thank you  @Erwin-vd-Zwart
worked perfect
You always save my time 🙂
Best Regards,
Replies 7
Erwin-vd-Zwart
Janeway
Posted: ‎2020-12-20 07:27 AM
1173
Can you give a sample how the time is formated? Is it xx:xx::xx ?
Where is this time comming from as the normal 3byte time object holds a table with day/hour/min/sec and you mention a string,
we can do a string.split('13:14:15', ':') and that would return a table with 3 values -> {hour, min,sec} -> {13,14,15}
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-12-20 07:30 AM
1171
hello @Erwin-vd-Zwart
its xx:xx
I got this time from an API server
Best Regards,
Erwin-vd-Zwart
Janeway
1169
log(hour,minute)
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-12-20 07:40 AM
1165
I got this error :
Resident script:13: attempt to index global 'spliited' (a nil value)
stack traceback:
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2020-12-20 07:41 AM
1163
Yeah i already updated the sample as i made a typo (:
IC_Systems
Captain IC_Systems
Captain
1160
worked perfect
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2020-12-20 07:47 AM
That’s my job (: Your welcome!
