hello
Script help 🙂
I want to make an action if any objects with a defined tag changed to a specific value.
for example, I want to turn On the fan if any light with a tag bath is on.
best regards,
Hey Nasser,
maybe the attached one will help. You just need to adapt the "Output" object which is was requested as 8Bit.
Hey Nasser,
thank you @Thomas_Rohde direct to the point 🙂
appreciate your help
do you have advanced manual or documents regarding Lua Programming in Spacelynk?
If there ar something more advanced than "AN046_Programming_in_Lua_with_spaceLYnk"
regards,
IF I want to do more functions like
if all true
or
if all false
regards,
Hello Nasser,
unfortuntely we do not have any more advanced description/manual/guide/training.
From a certain level it is kind of learning from script to script.
When you struggle at some point feel free to raise your questions here because in this case others can learn/participate too.
I make a counter to do
if all false
take a look @Thomas_Rohde
count =0
Hello Nasser,
according to "IF I want to do more functions like, if all true / if all false"
instead of using the tags you can do it as well "by foot". Means you can address all the needed GAs directly within the script.
As shown in the AN046 page 31 (Chapter 3.5). This is maybe a bit more obvious how it is working and to do a kind of bug tracking in case something doesn't work as expected.
Hey Nasser,
interesting approach!
What do you think about just changig one line of the original script?
-- When one of them is true sent defined 8BitValue >>>>> When one of them is true sent not defined 8BitValue
if OneValueTrue then >>>>> if OneValueTrue == false then
So there are many ways to walk 😉
