Retain Value for movement detector disable function
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Retain Value for movement detector disable function
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-10-20 01:46 AM . Last Modified: ‎2024-07-14 11:47 PM
857
hello
I used KNX ARGUS (MTN630819) to control lights and AC, I used two different blocks
I let the user enable and disable each block from SPACELYNK using the Disable function.
the issue comes when power off or KNX bus reset, the disable function (Locking object) become disabled regardless of the user settings.
@Erwin-vd-Zwart
any advice will be welcomed,
regards,
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
Thomas_Rohde
Sisko
Posted: ‎2020-10-20 07:19 AM
4
839
Hello nasser_ic-syste,
I dont know about how many rooms we are talking here in your project.
In case there is no W4K/sL within the project so that we cant work with a script ...
And maybe it is only for one/two rooms we could try to realize a solution with unsued switch-channel
which can keep their last position during power off. So that we "reuse" the feedback object?!
Kind regards
Thomas
Application Design Engineer
Erwin-vd-Zwart
Janeway
Posted: ‎2020-10-20 07:30 AM
1
836
Another thing i’m interested in is why is this a big issue? Usually the knx bus is always powered, and how often does a interruption occur? If you have a lot of interruptions isn’t it better idea to use a PSU with a backup battery attached to guarantee a working bus?
Replies 7
Erwin-vd-Zwart
Janeway
Posted: ‎2020-10-20 01:59 AM . Last Modified: ‎2020-10-20 01:59 AM
854
Did you try to change the "Activation time of the disable function" from "Active during telegram reception" to "After download/bus voltage recovery"?
Not sure if this is a retain value (so it checks previous state) or just simply activate on startup, i hope the first (:
If this not works o don't see any way to do it from the application, only way then is to use a script to solve it, i would suggest to try above first and if that does not works as expected we can look at some way to script it..
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-10-20 04:09 AM . Last Modified: ‎2020-10-20 04:09 AM
849
hello @Erwin-vd-Zwart
I tried that before
unfortunately, it does the second one (activate on startup)
 changing the flags for the locking object could help?
regards,
Best Regards,
Thomas_Rohde
Sisko
4
840
Kind regards
Thomas
Erwin-vd-Zwart
Janeway
1
837
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-10-20 09:39 AM
Thank you @Thomas_Rohde  and @Erwin-vd-Zwart
I agree that using UPS will solve the issue, because of that, we use UPS source in all of our projects
but in this case, we test the worst scenarios in our office and we face this issue.
Maybe it's not right thinking in this way and making things more complicated!
I share this issue here to hear from experts.
Appreciate your comments
Best Regards,
Best Regards,
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-10-20 09:40 AM
830
@Thomas_Rohde  I see an attachment sign beside your comments, but there is no attached file!
Best Regards,
Thomas_Rohde
Sisko
Posted: ‎2020-10-20 11:16 PM
I have no clew what happend there?!
I havent placed an attachment.
Sorry for this!
Kind regards
Thomas
