SpaceLynk CPU/IO not stable
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • SpaceLynk CPU/IO not stable
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-10-10 11:55 PM . Last Modified: ‎2024-07-14 11:47 PM
691
Hello Every one
SpaceLynk V2.5.1 CPU/IO rises above "1"  while I am not working on it.
Also some times it stops responding for a while (like one time in a month)
I attached the Script Backup to check if there are any script issues.
I couldn't attach the file here so I uploaded it to my Google drive
here is the link: https://drive.google.com/drive/folders/1Xc6eDputukmcyq5JPAucRKRlQsI2qrF7?usp=sharing
regards
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Scripts
  • SpaceLYnk
Erwin-vd-Zwart
Janeway
Posted: ‎2020-10-12 01:39 AM
673
No, the CPU load should be on average not higher then 0.7, some peaks can be higher at some high traffic moments..
I have seen in some rare cases that the Touch app can increase the CPU load, you might want to try to uninstall Touch (2 and/or 3), reboot, check the load and re-install touch.
Replies 4
Erwin-vd-Zwart
Janeway
Posted: ‎2020-10-11 12:19 AM . Last Modified: ‎2020-10-11 12:23 AM
688
Can you install the processes app from the store and check what process is causing the peak, this way you also know what script might hold loops or inefficient code.
Another way of checking what script might  cause a lot of cpu load is disable all your scripts, reboot and enable them one by one until your cpu load shoots through the roof.
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-10-11 02:26 AM
684
Hello @Erwin-vd-Zwart
I already installed the processor app and try to figure out if scripts cause CPU load, but the issue that the load is not continuous.
If there a loop in the script the CPU load will increase to a high level and will not go down until the script disabled, but I am not facing a similar issue.
I also tried to disable all scripts and Enable one by one, but nothing changed.
I don't know if it's normal to get a CPU load more than "1" when not working on the SL.
Any advice?
best regads
Best Regards,
Erwin-vd-Zwart
Janeway
674
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-10-13 03:23 AM
Thank you  @Erwin-vd-Zwart
I tried your advice about touch3, and CPU seems good
I will check the CPU/IO periodically If I face any issues I will inform you
best regards.
Best Regards,
