Wiser for KNX (LSS100100). Error connecting via Wiser KNX app
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Wiser for KNX (LSS100100). Error connecting via Wiser KNX app
Thomas_Rohde
Sisko Thomas_Rohde Sisko
128
Erwin-vd-Zwart
Sisko Erwin-vd-Zwart Sisko
56
Heribert_Dölger
Lt. Commander Heribert_Dölger Lt. Commander
30
FZetina
Lt. Commander FZetina Lt. Commander
29
Back to SpaceLogic KNX Forum
Andrii90x
Lieutenant | EcoXpert Master Andrii90x Lieutenant | EcoXpert Master
Posted: ‎2025-04-17 03:57 AM
2511
Hello. I use Wiser for KNX (LSS100100) and Wiser KNX app on iPhone. When i try to connect to Wiser for KNX thought  Wiser KNX app i have a warning "Something went wrong while initializing the appication. The controller seems to be offline." and there is also the ability to choose further action "Try again", "Ignore" or "Logout". The connection will not be successfully whatever i choose. This has been going on for a day already. The result is the same when I try to make connection through another iPhone. The internet connection is ok. Moreover I can connect to Wiser for KNX (LSS100100) using WEB interface and i see that it works normally and i can operate it. Of course i can restart the device and everything can be normal again, but in this case i will not actually know what was the problem and it can happen again. You can see the warning and some pictures from WEB interface in the attached pictures. Can someone help me?
  • Mobile App
  • Wiser for KNX
Replies 28
Erwin-vd-Zwart
Sisko
Posted: ‎2025-04-17 09:29 PM
2457
@Andrii90x
Did it ever worked or is this a new setup?
Some first steps:
Check the DNS and default GW,
Make sure you have create a Touch Visu with (app compatible) control items that needs to be showed in the app.
Make sure that all apps are updated currently -> Automations v1.0.2, Cloud connector v1.12.2,  KNX IoT 3rd Party API v1.31.4 and Touch 3 v3.17.3
Check on those apps the "update automatically" flag to be sure they are always up to date in the future.
Andrii90x
Posted: ‎2025-04-18 01:54 AM
It looks like you answered me in logic machine forum... now i will write you here 🙃
"Did it ever worked or is this a new setup?" - it has been working for a long period of time, but now it doesn't work.
"Make sure you have create a Touch Visu with (app compatible) control items that needs to be showed in the app." - i did it and it worked before.
I checked everything written above, but it still doesn't work.
Andrii90x
Posted: ‎2025-04-18 03:11 AM
7
2435
we restarted the controlled and now it works normally... but we still don't know what was the cause of this problem
Erwin-vd-Zwart
Sisko
Posted: ‎2025-04-18 04:52 AM . Last Modified: ‎2025-04-18 04:53 AM
@Andrii90x
Yes i contribute to the forum as many W4K/SL users asking questions there, this is the place where you need to be for SE..
No idea what it could have been, never heared an issue like that, i use it myself privately for quite a while (as pre production tester) and works all the time..
Good that it's solved for now..
FZetina
Lt. Commander
Posted: ‎2025-04-22 02:07 AM
6
2342
Hi
This error is normally shown when there is a communication between the controller, cloud and app. In many cases, when the controller, for some reason, is performing some actions that overload the processor, it causes this. After rebooting the controller, the issue goes away. If the issue comes back again is good to check in more detail what could be causing this (loops in the telegrams, multiple scripts, etc.
Fernando Zetina
Andrii90x
Posted: ‎2025-04-25 05:17 AM
Thank you for the answer.
geir_eas_no_bfo
Lt. Commander geir_eas_no_bfo
Lt. Commander
Posted: ‎2025-04-28 04:04 AM
I have the same problem regulary/ very often.
You need to restart the app, when this accoures.
It happens almosty every time when you try to open Wiser for KNX and when it has been "a sleep" on the iphone.
(Must put in a notice that my controller is in a "bad" condition regarding "overload" on KNX bus-->because of the wiser zigbee gateway)
BR
GIA
Erwin-vd-Zwart
Sisko
Posted: ‎2025-04-28 10:41 PM . Last Modified: ‎2025-04-28 10:44 PM
Don’t use normal objects for Zigbee mapping when there is nothing that acknowledges the updates (aka when only used for visu or script) , only use normal objects when there is a receiving KNX device on the same address, this way the acknowledgement is being sent by the KNX recipient device.
geir_eas_no_bfo
Lt. Commander
Posted: ‎2025-04-29 11:10 PM
2121
ohh, okay. Tanx!
I did not know.
Is that mensioned in the manual?
BR
GIA
Erwin-vd-Zwart
Sisko
Posted: ‎2025-04-30 03:47 AM . Last Modified: ‎2025-04-30 04:11 AM
@geir_eas_no_bfo
No as it has nothing to do with the device itself, this is basic KNX behavior, when sending a telegram on the KNX bus that is not acknowledged by a device/object, the telegram is repeated 3 times (or less when acknowleged), so if you setup a KNX system you have to take this always into account, this counts for any value that is published on the bus regardless of the origin (KNX/Modbus/Bacnet/Zigbee/TCP-IP etc), what counts is the KNX telegram that is send on the bus MUST to be acknowledged by something, if ACK is not received it will always be repeated x times..
When for example you have a pushbutton sending to a GA that holds no receiving object, this telegram is also repeated 3 times as it won't be acknowledged by a actuator that normally receives this telegram..
Snippet from the KNX protocol document:
geir_eas_no_bfo
Lt. Commander
Posted: ‎2025-04-30 04:25 AM
Okay, tanx Erwin!
It makes sense when you point out this😮
Now I know the different between normal vs virtual grup objects. Did not think of that! SO Virtual gruop objects is the way then👌
Unfortently selv learned in the WiserKNX world.
BR
GIA
Andrii90x
Posted: ‎2025-05-15 12:31 AM
2027
Can the error in the picture below be a reason of the communication error which we are talking about (i see it when i power up (restart) the device)? And i don't know what this error mean, because i haven't got a script called "apit3".possible reason.png
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2025-05-15 11:38 PM
Take a look at traffic lights to be sure everything it's ok...
Thomas_Rohde
Sisko
Posted: ‎2025-05-23 02:39 AM
1929
Hello Andrii90x!
I dont think so.
Do you still get this messages?
Kind regards
Thomas
Application Design Engineer
geir_eas_no_bfo
Lt. Commander
Posted: ‎2025-05-25 11:16 PM
I have the same problem all the time, it seems to happen when you re-enter the app after a short periode of time. When the applications connection has been shut down for a while, it does not seem to happen.
(Traffic lights is now green)
A timeout issue?
BR
GIA
Andrii90x
Posted: ‎2025-06-06 06:37 AM
1430
Hello 😊
Now i don't get this message. But i will look at "Log of alarms" and "traffic lights" when i get it again. I will let you know. Thank you.
Thomas_Rohde
Sisko
Posted: ‎2025-06-18 03:46 AM
1105
Hello Andrii90!
Any update on your topic?
Kind regards
Thomas
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-06-22 01:49 AM
Hello Dears,
I have the same issue, I tried the suggested solutions here but didnt work!
I notice this error in the Error logs:
apit3
Line 0: attempt to index field 'settings' (a nil value)
Best Regards,
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-06-24 04:07 AM . Last Modified: ‎2025-06-24 04:10 AM
any idea @Thomas_Rohde @Erwin-vd-Zwart @FZetina
here is the Touch backup
Touch created by help of https://community.se.com/t5/SpaceLogic-KNX-Forum/Generate-Wiser-JSON-using-AI/td-p/512817
Best Regards,
touch_backup.rar
Erwin-vd-Zwart
Sisko
Posted: ‎2025-06-25 01:20 AM . Last Modified: ‎2025-06-25 01:21 AM
@IC_Systems
What happens if you create a test Touch with a few elements via the user interface so without your AI approach, does it work normally?
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-06-26 02:23 AM
Thank you @Erwin-vd-Zwart
yes its work, the issue with the AI generated file, its missing some essential properties for the application, but I was confused because its open on the Touch app without errors.
I take care of that and fix the issues by help of AI 🙂 and now its work.
Best Regards,
Erwin-vd-Zwart
Sisko
Posted: ‎2025-06-26 11:09 PM
This is why I don’t like AI, you are quite skilled to debug the situation and solve it yourself, but i get so many questions about AI generated scripting (all kinds of) and it doesn’t work.
I came to a point where i tell the novice users “put it back in AI and ask what’s wrong” 😉
I think you should use AI to speed up processes but always be skilled to understand what’s going on, but i see most of the time people are using it without any clue what’s they are doing and relying on the intelligence of the AI, i think that is bad..
Anyway, great that you found the issue!
Andrii90x
Posted: ‎2025-06-29 11:15 PM . Last Modified: ‎2025-06-29 11:18 PM
Hello. Now it still works nornally, without this error.
Thomas_Rohde
Sisko
Posted: ‎2025-07-11 12:25 AM
700
Hello Andrii90x !
Does it mean we can close this thread?
If so .. please select a provided answer as "Solution".
Wish to you a great weekend 😊
Kind regards
Thomas
Andrii90x
Posted: ‎2025-07-14 11:26 PM
Hello 😊 let this thread still be opened... i will close it if i will not notice this error for about two monthes 🙃
Andrii90x
Posted: ‎2025-07-28 12:23 AM
Hello. I again have this message in Fiser KNX app. I can control the system from Fiser KNX app again only after rebooting the system. I have made screenshots from the system analysis sections before rebooting (while i haven't got an access to the system from Fiser KNX app). I want to notice that i lost an access to the system from Fiser KNX app on Saturday 26.07.2025.
Mohammed_Suhan
Mohammed_Suhan
Cadet
Posted: ‎2025-07-28 09:52 AM
Hi, I had similar issue. Once I reboot the wiser everything seems to work fine. So I have made a work around to schedule wiser to reboot everyday in early hours by using a script mention in the attached pdf.
geir_eas_no_bfo
Lt. Commander
Posted: ‎2025-08-18 02:05 AM
Hi, I have this initialization problem all the time.
How long does your wiser take from when you open the app until it is fully initialized for control? Sometimes it takes 5-10 seconds, even if you are on wifi.
I think this is not satisfactory in 2025. Is there no way to make this wiser "always ready" especially if it is on wifi?
If you use APPLE homekit, over wifi, it is lightning fast via wiser.
How do you start troubleshooting?
BR
GIA
