Generate Wiser JSON using AI
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Generate Wiser JSON using AI
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_DĂślger
Commander Heribert_DĂślger Commander
31
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-06-16 06:24 AM . Last Modified: ‎2025-06-16 06:47 AM
1
521
Hello everyone,
I wanted to share a successful workflow I've developed for automating smart home configurations. I was able to generate a complete Schneider Electric Wiser (touch 3) JSON configuration file with the help of an AI assistant.
The process was remarkably efficient: I provided the AI with an exported XML of the project's KNX group addresses with a clear floors and rooms structure, and a sample JSON backup file containing the required functions (in this case, on/off switches and shutters). The AI then parsed both files and generated the complete, correctly formatted JSON code for the entire project.
This method significantly reduced manual programming time and the potential for human error, It will be great if such feature integrate inside touch 3!
I've included some images of the process below.
I asked AI to make a prototype/agent for testing
Link: https://g.co/gemini/share/307fb0928357
Best Regards,
  • Information
  • Wiser for KNX
Thomas_Rohde
Sisko
Posted: ‎2025-06-18 03:31 AM
Hello IC_Systems!
That sounds great and super interesting.
Need to ckeck it out đŸ˜
MANY THANKS for sharing!!
Kind regards
Thomas
Application Design Engineer
Terms & Conditions Privacy Notice Change your Cookie Settings Š 2025 Schneider Electric
