MTN6725-0001 fw1.3 replacement dead device with fw3.1
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • MTN6725-0001 fw1.3 replacement dead device with fw3.1
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
FZetina
Commander FZetina Commander
29
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2021-07-14 06:38 AM . Last Modified: ‎2024-07-14 11:46 PM
2179
Hello
I want to replace old broken device MTN6725-0001 fw1.3 (DALIControl IP 1 7307/1.0b) to new MTN6725-0001 fw3.1 DALIControl IP 1 (DCA7310/1.0)
I have found in document (KNX- DALI Gateway REG-K/1/16(64)/64/IP1-ETS Software Description (EN) (Version V7310/1.0) on page 30 that there is restore function. I see that i can't download ETS project into device.
How replacement should look like, do i need to start from zero?
Can i downgrade firmware in new gateway and download configuration form ETS?
When i try to program gateway from ets i get this:
KNX faultKNX fault
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Local App
Tags (6)
  • firmware
  • fw1.3
  • fw3.1
  • KNX fault
  • mtn6725-0001
  • replacement
Thomas_Rohde
Sisko
Posted: ‎2021-07-15 01:37 AM
8
2173
Hello Piotr,
to "Can i downgrade firmware in new gateway and download configuration form ETS?"
YES, you can downgrade the device to FW-Version 1.3.9 (Link to FW). Then it is compatible with your current ETS/PlugIn Version.
Means after the downgrade you can reuse the KNX-Part.
Related to the DALI-Part. If you didnt saved the DALI-Information with the dedicated function in the PlugIn (handled with a file) before you need to do the DALI-Part again. So it is helpfull to make a backup of the DALI-Configuration when you use the FW-Versions with the PlugIn.
When you use the new FW in combination with the dedicated ETS-APP then the DALI-Information are directly stored within the ETS.
Kind regards
Thomas
Application Design Engineer
Replies 9
Thomas_Rohde
Sisko
8
2174
Hello Piotr,
Kind regards
Thomas
PiotrJakubczyk
Sisko
Posted: ‎2021-07-15 04:33 AM
2169
Thank you for fast reply @Thomas_Rohde
Gateway device must be online on DALI network to make this backup file, or it can be done offline?
Thomas_Rohde
Sisko
Posted: ‎2021-07-15 04:43 AM
2167
Hello Piotr,
if you have the backup file I think you can do it offline.
Kind regards
Thomas
domotiqa
Lt. Commander domotiqa
Lt. Commander
Posted: ‎2021-09-16 12:42 AM
2156
Is it possible to switch a dali 0001 to dali pro secure device 0101 with the backup file of the old one.
Or do I need to reprogram all ?
Smarthome & Smartbuilding Expert
Tags (4)
  • dali
  • mtn6725-0001
  • MTN6725-0101
AleksRibar
AleksRibar
Cadet
Posted: ‎2024-08-28 05:59 AM
1833
Hello i have the same problem as Mr Piotr regarding the firmware.
Can you share the link again, please?
Aleksandar
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2024-08-29 11:44 PM
2
1823
Hello Domotiqa,
the database format of the MTN6725-0001 is totally different from the new model MTN6725-0101, therefore, unfortunately, you cannot use its backup file.
However, the new installation procedure now allows you to maintain the configuration created with an external tool, therefore, by selecting that option, you should be able to maintain the association of the ECGs in the DALI groups.
PiotrJakubczyk
Sisko
Posted: ‎2024-08-30 01:50 AM
1
1814
@domotiqa is it similar issue? https://community.se.com/t5/SpaceLogic-KNX-Forum/Import-DALI-GW-ETS-DCA-Configuration/td-p/436310
Thomas_Rohde
Sisko
Posted: ‎2024-08-30 03:07 AM
Hello Aleksandar,
here the requested file.
Kind regards
Thomas
SCHNEIDER_e64_UpgradeTool_V1_3_9.zip
domotiqa
Lt. Commander
Posted: ‎2024-09-02 02:35 AM
yes 😉
