Remote Services stop working after upgrade to V3.0
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Remote Services stop working after upgrade to V3.0
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2024-08-08 04:09 AM . Last Modified: ‎2024-08-08 05:53 AM
874
Hello dears,
I was using remote services to receive http command from Zennio getface IP intercom.
after upgrading SL to V3.0 it stop working.
I know that the authentication moved from Basic to sessions, and the Basic authentication could be enabled in the remote service in the next update release.
Could you confirm this, also the proposed date for the next version update?
Edit:
If the new update will take time, could I downgrade From V3.0 to V2.8.3, do you have any concerns?
Best Regards,
  • SpaceLYnk
Replies 5
Erwin-vd-Zwart
Janeway
Posted: ‎2024-08-09 09:44 PM
832
Downgrade is not supported, the only way to do that is reflash the SD card and use old FW, but you cannot use a backup from 3.0 so you need old version backup
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2024-08-10 04:10 AM . Last Modified: ‎2024-08-10 04:11 AM
Hello @Erwin-vd-Zwart
I try downgrade SL on my office as a test and it downgraded successfully, but I am afraid to downgrade a working site while its not supported.
do you have an approximate date for the next release?
If the next release will take a long time then I will try your tips
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2024-08-10 10:25 PM
797
I’m not from R&D so i have no clue and currently on holiday in Italy 🇮🇹
@PetrMares Do you have an answer?
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2024-08-10 11:37 PM
Thank you for answering during your holiday, Enjoy your time.
Best Regards,
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2024-09-01 12:58 AM . Last Modified: ‎2024-09-01 01:00 AM
Hello Team,
I need to provide the customer with an estimated date. Unfortunately, the recent FW 3.0 update has consumed a significant amount of my time and that of my colleagues as we determined the issue was related to the upgrade. Schneider failed to notify us about this problem and did not offer a hotfix or workaround.
I hope you pay attention to this matter.
Best Regards,
