Import DALI GW ETS DCA Configuration
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Import DALI GW ETS DCA Configuration
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2023-06-01 12:54 AM . Last Modified: ‎2024-07-14 11:42 PM
1804
Hello Dears,
I have DALI GW (MTN6725-0001), which is broken in site after it was configured.
I will replace it with the new DALI Pro
Is there any concern to import its DCA configuration into the new DALI Pro (MTN6725-0101)?
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Protocols
gianmarco.nardo
Ensign gianmarco.nardo Ensign
Ensign
Posted: ‎2023-06-01 05:02 AM
If you have the DCA xml file from the MTN6725-0001 you can apply it to the MTN6725-0101.
Extras--> Import ETS-DCA configuration--> Restore
gianmarco.nardo
Ensign
domotiqa
Lt. Commander domotiqa
Lt. Commander
Posted: ‎2024-10-09 06:13 AM
I also have a dALI MTN6725-0001 replace by a MTN6725-0003. I tried to export to xml, then import in the new one . But nothing happen. Here my xml. Should it work ?
Smarthome & Smartbuilding Expert
