Hello Dears,
How to correctly set Multiple MTN6303-0019 one as Master and others as Slave?
I set the slave input as active for the master and link it with the switch output from the other slaves; but it didn't functioning well!
Hello IC_Systems,
please take a look at the following picture.
I guess it makes it very clear how to set it up.
Thank you @Thomas_Rohde ,
So to get the most similar to the master slave in the ARGUS motion detector the slave input should be set to (ON). Right?
thank you for this conclusion @Thomas_Rohde
Hello IC_Systems,
Yes correct. But at the end ... it is a question of taste. Because with both variants you will make it work.
did you put one group address from master swtich output to start the light, and secon group adress for slave input and other slawe sitich output?
thx
hello @ikosi
use one GA for Slave and Master and the other one for the light/switch
this is how I make it.
thx, I have 5 slaves , and i put all 5 in same group address is that ok?
this is setting for master
this is settings for all slaves
group address for slave
thx for help
