Gree Gateway modbus - Wiser connectivity
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Gree Gateway modbus - Wiser connectivity
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
TechWhiz123
Lieutenant JG TechWhiz123 Lieutenant JG
Lieutenant JG
Posted: ‎2024-11-19 04:16 AM
2536
Dears
I'm trying to connect Modbus gateway from GREE  ME50-00/EG(M) to control HVAC system via Wiser for KNX (LSS100100), but couldn't read the values, it always give me invalid CRC i tried to connect to AS-p and and everything worked normally,
the data as following :
baud rate: 9600bps; standard: RS485;  Address = 2
What is the problem ?
thanks,
  • Wiser for KNX
Replies 6
Thomas_Rohde
Sisko
Posted: ‎2024-11-19 07:23 AM
Hello Hamza_Nasri!
Would it be possible to share a tiny video of your connection and some pictures of your configuration/error message?
This would help to get a better understanding of your problem.
Kind regards
Thomas
Application Design Engineer
TechWhiz123
Lieutenant JG
Posted: ‎2024-11-27 10:22 AM
1
2472
Dear @Thomas_Rohde ,
Kindly find attached data requested from your side,
Please let me know for any further clarifications,
Best Regards,
Thomas_Rohde
Sisko
Posted: ‎2024-11-28 08:10 AM
Hello Hamza_nasri!
Many THANKS for the material you shared. I would propose to enrich the profile with more attributes.
Beside that, I made some adaptations. Within the picture you can identify the differences:
I would propose to try the attached file (I had to zip it as the ending *.json is not accepted).
The changes will not help to find the device when you do a scan.
So you need to add it manually to the list of Modbus devices.
To make a quick test .. I would link a Group-Address to the "Ambient temperature"
in order to see if sensefull values coming.
You can also identify, that something is wrong, in case the Modbus-Device get highlighted in slight red color.
Please have also in mind that sometimes it is needed to shift the register-addresses by "1".
Please let me know 🙂
Kind regards
Thomas
GreeGW_TRE.zip
Erwin-vd-Zwart
Janeway
Posted: ‎2024-11-28 09:48 PM . Last Modified: ‎2024-11-28 09:50 PM
Device scan is not supported by all Modbus devices so this won’t tell you much.
Also starting with a template without testing the register(s) first (and see the correct value as a response) is not the best approach..
You should always start with the read test to determine the connection, registers and possibly if a -1 offset is needed.
With the results of your read test(s) you start building your profile or you end up facing the issues you have now..
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2024-12-09 12:48 AM
Interesting fields in testing
The answer, validates comunication.. even if the answer is 0.
Thomas_Rohde
Sisko
Posted: ‎2025-02-11 01:05 AM
Hello Hamza_Nasri!
Is this topic solved?
Kind regards
Thomas
