KNX FBEditor
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • KNX FBEditor
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Mario.gayed
Lieutenant | EcoXpert Master Mario.gayed Lieutenant | EcoXpert Master
Posted: ‎2024-09-22 01:47 AM
1676
KNX FBEditor
Hi there, is there any guide for how to use the Function block diagram (FBEditor ) in the KNX Wiser ? I'm trying to write a FB script rather than the lua one , but i'm confused about the event that needed to run a block
  • Other
  • Scripts
  • SpaceLYnk
Thomas_Rohde
Sisko
Posted: ‎2024-09-23 01:29 AM
1619
Hello Mario Gayed,
unfortunately we do not have such kind of documentation.
What are you struggling with?
Or what kind of solution you want to create with it?
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
1620
Hello Mario Gayed,
Kind regards
Thomas
Bjolil
Bjolil
Cadet
Posted: ‎2025-02-09 11:42 PM
New to SpaceLync/Wiser, and I have a specific question that I dont seem to find the answer to.
I have made som addition blocks where the first is "timed" (takes two values from KNX) and the following block  (takes one of its values from the first block, and the other from a KNX group) is event based.
I then get an error saying that no event is set for the event driven block, but there is also no "connectionpoint" on the block for an event input.
So i need this to add 10-15 values together in a string (adding 1 to 2, that result to 3, that result to 4 and so on)
This is for sumation of ventilation supplyairvalues to in the enda make a percentage value for the exhaust air.
If there is an easier way to do this that is of course also welcome.
Erwin-vd-Zwart
Janeway
Posted: ‎2025-02-10 10:25 PM . Last Modified: ‎2025-02-10 10:31 PM
@Bjolil
Just add a TAG to the objects you need to calculate and use a small event based script attached to the TAG (in this sample "AVG")
myobjects = grp.tag('AVG')
avg = 0
for _, obj in ipairs(myobjects) do
avg = avg + obj.value
end
avg = math.round(avg / #myobjects, 2)
grp.checkwrite('1/1/1', avg)
