Additional heating stage cyclically turning off
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Additional heating stage cyclically turning off
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
KisevcompanyLTD
KisevcompanyLTD
Cadet
Posted: ‎2024-11-12 12:17 AM
1035
Hello!
I'm using the Valve Drive Controller to Control basic and additional heating.
I figured out that I have an issue with the Cycle time for automatic transimission parameter.
Every time I set the setpoint high enouht to power on the additional stage - It works until the Cycle time for automatic transmission passes. Then the Additional stage receives a '1' and a "0" right after. After that the additional stage remains switched off. Basic stage working perfectrly fine.
Now I've switched off the Cycle time for automatic transimission and the system is running well, but I know that I'm messing up with something.
Please let me know if you have any suggestions!
Thank you so much!
  • SpaceLogic devices
Thomas_Rohde
Sisko
Posted: ‎2024-12-06 12:23 AM
Hi KisevcompanyLTD!
To "Can you please tell me where can I send some Screenshots - Because the forum doesn't allow me to Attach any. "
Hmm ... this sounds strange!
There are two ways to attach pictures:
1. You include them directly into your text at the right position. To do so you can use the camera icon to include your picture. Of course your picture needs to be in accepted format.
2. You can use the dedicated functionality to attach file to your thread.
Again, of course your picture needs to be in accepted format.
Maybe you can try with a different browser?
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Posted: ‎2024-11-20 02:39 AM
975
Hi KisevcompanyLTD!
Sorry for the late reply! Can you provide more details (Telegram log) in order to see clearly what happens and what are the dedicated temperatures.
Kind regards
Thomas
KisevcompanyLTD
KisevcompanyLTD
Cadet
Posted: ‎2024-12-04 10:45 AM
929
Hello, and thank you for your answer!
Thank you so much!
Thomas_Rohde
Sisko
Hi KisevcompanyLTD!
Kind regards
Thomas
