APL ERROR IN MTN6212-03XX
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • APL ERROR IN MTN6212-03XX
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
NAEIM
NAEIM
Cadet
Posted: ‎2025-01-15 03:24 AM
992
Hi colleagues,
I have a problem with a mtn6212-03. On screen it shows "APL" and I'm not able to download application via ETS5.7.4 on it? I tested all .KNXPROD and .VD files on it, but they didn't work. Is there the same problem for others? Does it have a solution?
Thanks for your consideration in advance
Software problem at MTN6212-0319 fw
  • SpaceLogic devices
Heribert_Dölger
Commander
Posted: ‎2025-01-20 12:43 AM
Hello NAEIM
Can you please perform ETS device info to see what application is in the device? Is it a new product that shows this behaviour or has it been working before? If latter: do you know what actions had been performed with it?
MTN6212-03xx is not using a plug-in as Cristiano thought. No need to program it in compatbility mode.
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2025-01-16 09:19 AM . Last Modified: ‎2025-01-16 09:19 AM
948
Hello NAEIM,
"APL" on the display indicates that a previous loaded application program has been unloaded from the device, as also shown in the ETS download history.
Have you tried to use a different Bus interface?
I honestly don't remember if those devices need a plugin or not.
Maybe you can try to enable the "compatibility" mode in the general settings of ETS and then try to download the application program again.
NAEIM
NAEIM
Cadet
Posted: ‎2025-01-17 11:31 PM
Hello Cristiano,
Thanks for your attention. I've tried all downloads when compatibility mode was enabled, unfortunately I had the problem again. for these devices I didn't find the plugin and I think they don't have any. I'm trying to find the solution as soon and then share it here.
Heribert_Dölger
Commander
Hello NAEIM
