Continue
  • My Subscriptions
  • Events
Switch/Blind Master MTN6705-0008 pulse output
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Switch/Blind Master MTN6705-0008 pulse output
Thomas_Rohde
Thomas_Rohde Champion
143
Erwin-vd-Zwart
Erwin-vd-Zwart Champion
66
Heribert_Dölger
Heribert_Dölger Leader
37
Back to SpaceLogic KNX Forum
PiotrJakubczyk
PiotrJakubczyk Leader
Leader
Posted: ‎2025-01-17 06:27 AM
2
1294
Hello
How to configure pulse output for Switch/Blind master less than 5 seconds?
I'm able to configure pulse output more than 5 second as Staircase lighting time function... but can't find how to generate pulse for example 1 second.
  • SpaceLogic devices
sesa46957_bridg
sesa46957_bridg Contributor
Contributor
Posted: ‎2025-01-19 09:32 AM
Hi Piotr
The minimum duration is 5 seconds, and there is no setting below this.
We will evaluate this data to improve this function. tks.
Alexander_Remteks
Alexander_Remteks
Contributor
Posted: ‎2025-01-17 10:35 PM
Hi Piotr, i did short pulses using SpaceLogic LSS100200(or LSS100100) using LUA scripts for curtain control. Firstly I also plan to use starcase timer, but not possible to use very short settings with device.
Alexander
sesa46957_bridg
Contributor
Hi Piotr
