Is conversion of a 200 HP, 2-Speed, 460V, 3P Motor to VFD operation feasible? If so, what are the precautions?
  • Industrial Automation
  • Solutions for Motor Management
  • Is conversion of a 200 HP, 2-Speed, 460V, 3P Motor to VFD operation feasible? If so, what are the precautions?
BJacqz
Commander BJacqz Commander
48
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
13
Bastian_Schmitz
11
Back to Solutions for Motor Management
Finlfox
Finlfox
Cadet
Posted: ‎2023-02-16 08:39 AM . Last Modified: ‎2023-02-17 06:20 AM
1214
  • Low Voltage AC Drives
BJacqz
Commander
Posted: ‎2023-02-17 08:06 AM
The two speed motor can be used on Altivar. it is necessary to select corectly the drive in accordance with catalogue of the product.
Taking the power into account, I would propose Altivar ATV600 (mainly for "fluid" application) or ATV900 (mainly for "solid" application).
When connecting motor to drive, you can select one of the motor speed and keep this one, and only this one. Selection of drive has to be made according to motor power as well as motor current corresponding to the selected winding (see on motor name plate). I put the catalogue of Altivar Process on cc.
feel free to have also a look on our configurator : Product Selector tool  | Schneider Electric Global
Bruno Jacqz, Drives training leader
BJacqz
Commander
