Posted: 2023-02-17 05:12 AM . Last Modified: 2023-02-17 06:19 AM
I have an altivar 21 drive it runs very well in local mode but when given an external command in remote mode it does run and all the parameters are well set
Posted: 2023-02-17 07:48 AM
Could you explain what is your topic ? what occurs when you give external command ? A drawing of wiring could also be a good help for understanding exactly how is made installation.
Anyway, let me join the manual for this product, may be could help.
