How to implement SDI safety in ATV930
  • Industrial Automation
  • Solutions for Motor Management
  • How to implement SDI safety in ATV930
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Altivar Process (Low Voltage)
Back to Solutions for Motor Management
JohnShi
Crewman JohnShi Crewman
Crewman
Posted: ‎2024-01-23 10:16 PM
1266
A customer required safety functions in ATV930 series. Others like SLS I can found in module VW3A3802, but no SDI ( safe direction ) in the manual.  Does anyone have experience about SDI in ATV930?
  • Low Voltage AC Drives
  • ATV900
  • safety
  • SDI
LeoLazzaro
Lieutenant
Posted: ‎2024-11-04 06:01 AM
Dear Colleagues this function is not available in our Safety funtions by the moment . Thank you in advance
B.R.
BJacqz
Commander
Posted: ‎2024-04-16 11:51 PM
Hello John,
I am sorry to tell you this function does not exist in this card, and is not available in Altivar Safety functions.
Bruno Jacqz, Drives training leader
LeoLazzaro
Lieutenant
B.R.
JohnShi
Crewman
Posted: ‎2024-11-04 04:52 PM
Thanks a lot. Hope it will be available in the next step.
