Posted: 2024-10-24 11:02 AM . Last Modified: 2024-10-24 02:02 PM
Hello!
While integrating ATV-212 frequency converters into the system, I encountered extremely unfriendly documentation.
Parameter multipliers are not specified for all variables.
All frequencies are indicated with one decimal place, but the multiplier is 0.01.
Some turned out to be different for similar parameters, for example, for acceleration/decrease (ACC, DEC) it is 0.1, and for PID activation delay (F359) - 1, although both parameters are measured in seconds.
There are some parameters that I would really like to see when the converter is working. Such, for example, as analog signals at the VIA, VIB inputs, the state of the logic inputs, the FC value of the setpoint for regulation. It is also unclear in which register the network PID setpoint is stored. The diagram simply indicates: communication, it is written how to switch to it, but how and where to set it is not.
I got something out of the SoMove program, but it's still not enough.
Does anyone have complete modbus documentation for ATV-212 and ATV-312 frequency converters (I think the situation will be similar there), where these issues would be covered? Or maybe a ready-made custom table?
I have files:
ATV212_programming_manual_EN_S1A53838_03
ATV212 Communication Parameters Manual
ATV212_Modbus_manual_EN_S1A53844_02
ATV212 Quick Start Guide
Posted: 2024-11-05 07:01 AM
HI Miroshko ,I;m Offer manager of ATVProcess , I'm not expert in ATV212 but please find attached the modbus address manual for ATV212 and 312 please coud you confirm that this can solve your issue?
https://download.schneider-electric.com/doc/S1A53844/ATV212_Modbus_manual_EN_S1A53844_02.pdf
https://www.se.com/in/en/faqs/FA370036/
For new offers we have excel file more simple to use but i think you will find all info requested in these pdfs. If not please let me know exactly what are the addresses that you need to search internally. Thanks
Posted: 2024-10-28 09:16 AM
Adjusting the regulator was not a problem - it works in the mode that I need: the user can start it without BMS and adjust the set temperature with the FC parameter. But I cannot reproduce in the BMS either the signal that the VSD receives, its FC setting, I cannot adjust the setting.
I can see the signal emitted by this sensor over the network, but what if there is another sensor?
The setting in the picture is bound to an auxiliary variable and works only as a meter, it does not affect anything.
