ATS480 Soft Starter
  • Industrial Automation
  • Solutions for Motor Management
  • ATS480 Soft Starter
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Zika-Richard11
Ensign Zika-Richard11
Ensign
Posted: ‎2024-11-01 11:30 AM
1
1101
ATS480 Soft Starter
Hello experts, do you know how can I access all the parameters on the ATS480 Soft Starter?
Thank you in advance.
  • Soft Starters
  • ATS480
Ahmed_Alzafer
Lieutenant JG Ahmed_Alzafer Lieutenant JG
Lieutenant JG
Posted: ‎2024-11-04 05:36 AM
The ATS480 offers 3 levels of Access: Basic, Standard and Expert.
• Basic gives you access to these menus: Simply Start, Monitoring, Input/Output, Display, Diagnostics and Device Management
• Standard gives you access to ALL menus, but some parameters are still not visible
• Expert gives you access to all menus and all parameters.
To have access to all the parameters :
First go to Menu 10: My Preferences
Then select Parameter access.
Finally, choose Expert.
You can also watch the How to video on this subject to follow the procedure : https://youtu.be/V8m46_zYPg0
Ahmed_Alzafer
Lieutenant JG
