Atv212 fault code P29.9.
  • Industrial Automation
  • Solutions for Motor Management
  • Atv212 fault code P29.9.
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Perorochi
Perorochi
Cadet
Posted: ‎2022-09-05 03:31 AM . Last Modified: ‎2023-06-09 04:25 AM
After i pushed run button i got fault code P29.9. There is motor load in ammeter, even if i  cut off the main power it still got  fault code P29.9. untill i push stop button. The letter P was blinking, maybe 29.9 is freq but i don't know about letter P. Please help me, thanks.
  • Low Voltage AC Drives
  • atv212
Replies 0
