Back UPS Pro 650 Physical Replacement of Battery
  • Industrial Automation
  • Solutions for Motor Management
  • Back UPS Pro 650 Physical Replacement of Battery
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Posted: ‎2022-08-30 09:16 AM
I have a replacement battery for the UPS 650 Pro  which is seemingly identical in size and shape to the original. I find that the existing + cable (red) cannot extend to the battery's + terminal when replacement is inserted.
A ~2" jumper cable would work (if one were available), but I feel there has to be an alternative that I'm failing to see!
Suggestions appreciated (If a jumper is the only solution, where might it be obtained?)
Keith (ks9c)
Replies 0
