Auto tune of VSD
  • Industrial Automation
  • Solutions for Motor Management
  • Auto tune of VSD
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Posted: ‎2022-09-14 08:52 PM
1
1528
Auto tune of VSD
Dear Sir/Madam
 Usually, we do Autotune when the Electric motor is decoupled and in free-run mode. In some cases like an electro-gearbox which is very difficult to decouple, "Is it right to use Autotune without decoupling"?
BJacqz
Commander
Posted: ‎2022-09-22 01:46 AM
No problem to make autotune even motor coupled. It is better to make such autotune than not doing at all.
Our motor control has been improved on some products (ATV900 340 for example) allowing ACVC feature, this has to be used when high dynamic performances are requested by application. In this case ACVC propose to make autotunning in rotation, in this case, it is better to make autotune motor unloaded (allows better motor characteristics measurement) but once more, not mandatory.
Bruno Jacqz, Drives training leader
BJacqz
Commander
