Atv 312 drive Opf fault
  • Industrial Automation
  • Solutions for Motor Management
  • Atv 312 drive Opf fault
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Posted: ‎2020-07-21 09:17 PM . Last Modified: ‎2023-03-30 05:02 AM
3000
Drive fault output side is OK. But fault is active.
  • Low Voltage AC Drives
BJacqz
Commander
Posted: ‎2023-03-30 08:41 AM
In response to Anonymous user
Is it a commissioning or was it running before ? In case of commissioning, ensure you have entered motor name plate and did an autotuning.
In case of a sudden failure detection, check the system with another motor (could be smaller).
When you say 0V at output, in this case what are the status/settings of I/O (digital inputs) as well as the analogue input (position of potentiometer or speed reference .
Bruno Jacqz, Drives training leader
Posted: ‎2020-07-21 09:29 PM
2997
Motor and cables of invertor is OK. I have disabled the fault from drive. But after that I checked output voltage in invertor it is showing is '0' I need to know is this invertor internal fault or not. If internal fault how to solve this.
BJacqz
Commander
ABOC
ABOC
Cadet
Posted: ‎2024-07-11 01:25 AM
Hi Everyone please someone help me
I have a issue with my ATV 680C40Q4X1
There is this error message that is displayed on the HMI (ERR RET CONTACT AFE CRF3)
