Posted: 2024-06-27 12:48 PM
I have a 60 amp 2 pole GFI breaker supplying power to a 10 HP (46 amp) motor. the breaker handles the start up load with no issues. The motor appears to run solid at 46 amps. The breaker is tripping after a period of time. The motor supplier says there is no issue with the motor. All the wiring and terminations have been checked. The contactor has been replaced as there were signs of wearing and we wanted to eliminate this as a possible issue.
Does anyone have thought on this
Posted: 2024-06-28 05:57 AM
Hi Solectric, if I understand it well your question pertains to a motor management matter. I will then move your question to a more relevant forum.
