Altivar Process 900 simultaneous communication with profinet and modbus tcp
Select a Country
  • Industrial Automation
  • Solutions for Motor Management
  • Altivar Process 900 simultaneous communication with profinet and modbus tcp
BJacqz
BJacqz Mentor
49
LeoLazzaro
LeoLazzaro Troubleshooter
16
PriscilaCunha22
PriscilaCunha22 Troubleshooter
15
Back to Solutions for Motor Management
JhimmyJMQT1
JhimmyJMQT1
Explorer
Posted: ‎2024-06-24 09:19 AM
810
Dear Experts,
I hope this message finds you well. I have a question regarding the Altivar Process 900 drive. Is it possible to establish communication with the drive simultaneously using both Profinet and Modbus TCP protocols?
I appreciate any information you can provide on this matter.
  • Drives & Motor Control
  • Low Voltage AC Drives
  • Products
Bastian_Schmitz
Bastian_Schmitz Champion
Champion
Posted: ‎2024-08-06 01:28 PM
Yes this is possible and no problem. You could use Modbus TCP thorugh the internal Ethernet Ports, and also in parallel on the Profinet card. But you could only use one protocol at once to control the drive. But reading of values should be possible in parallel.
Bastian_Schmitz
Champion
