Diagnostic Procedure for ATV61 Short Circuit
Select a Country
  • Industrial Automation
  • Solutions for Motor Management
  • Diagnostic Procedure for ATV61 Short Circuit
BJacqz
BJacqz Mentor
49
LeoLazzaro
LeoLazzaro Troubleshooter
16
PriscilaCunha22
PriscilaCunha22 Troubleshooter
15
Altivar Machine
Back to Solutions for Motor Management
JhimmyJMQT1
JhimmyJMQT1
Explorer
Posted: ‎2024-08-19 03:22 PM
4493
Dear Experts,
I hope you'r doing well. I am reaching out to inquire about the diagnostic procedure for an ATV61 that experienced a short circuit in its power section. I have attached images of the ATV61 for your reference.
I would like to perform tests on the control and power boards to identify the root cause of the short circuit and the damaged component. This will enable us to provide a reliable diagnosis to the client and recommend replacing the ATV61 with another Schneider VFD.
Additionally, I am inquiring if you are aware of any Schneider Electric documentation that outlines specific tests to perform on this type of VFD, such as continuity tests, capacitance measurements, or other relevant diagnostic procedures
  • Drives & Motor Control
  • Training & How to
  • altivar
Kevin_McDonald
Kevin_McDonald Contributor
Contributor
Posted: ‎2024-08-20 07:16 AM
Hello Jhimmy,
Check out this FAQ on how to complete a static check for the ATV61 drives.  https://www.se.com/us/en/faqs/FA173615/
More FAQs are available to help with this request or you can contact your local country Customer Care Center.
Kevin_McDonald
Contributor
Hello Jhimmy,
