Altivar supply frequency
  • Industrial Automation
  • Solutions for Motor Management
  • Altivar supply frequency
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
AlgirdasSurgautas
AlgirdasSurgautas Cadet
Cadet
Posted: ‎2024-05-02 12:08 AM
683
What will happen for the drive if supply frequency will drop short time for 46-43Hz?
In the ATV600 manual written supply frequency 50Hz +-5%, that means lowest threshold 47,5Hz.
Does there any info about supply freqeancy?
Does there are any possible settings for supply requency?
BJacqz
Commander
Posted: ‎2024-09-04 06:27 AM
The frequency change will not directly reach to an internal fault detection as there is no direct monitoring on this electrical value as we can find on voltage. The topic is, it can change the DC signal inside the product then modify slightly the heating of device...This is mostly the change I can see in product.
Bruno Jacqz, Drives training leader
BJacqz
Commander
