ATV630 Bacnet IP
  • Industrial Automation
  • Solutions for Motor Management
  • ATV630 Bacnet IP
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Altivar Process (Low Voltage)
Back to Solutions for Motor Management
pablo.rivera
pablo.rivera Cadet
Cadet
Posted: ‎2023-11-16 03:44 AM
3
1243
ATV630 Bacnet IP
Does Schneider Electric have a communication solution for ATV630 Bacnet IP? Thanks.
  • Low Voltage AC Drives
Bastian_Schmitz
Admiral
Posted: ‎2024-05-16 12:36 PM
Schneider Electric did not offer any Drive which support BACnet IP. For ATV6xx you could use the follow Communication Card to use BACnet MS/TP VW3A3725. ATV212 offers directly BACnet MS/TP.
BrownSugar
Lieutenant JG BrownSugar Lieutenant JG
Lieutenant JG
Posted: ‎2023-11-17 05:40 AM
Thank you for the question
BJacqz
Commander
Posted: ‎2024-04-16 11:54 PM
Hello Pablo,
Bacnet IP is communication device for Building then the ATS212 is the Altivar for Building, and this type of communication is available in this product...
Bruno Jacqz, Drives training leader
Bastian_Schmitz
Admiral
