ATV6000 Drive Power Cell Fault.
  • Industrial Automation
  • Solutions for Motor Management
  • ATV6000 Drive Power Cell Fault.
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Myazan
Myazan
Cadet
Posted: ‎2024-06-05 11:51 PM
941
Dear Colleagues,
One of the power cell shows Fault. A Fault code is 0010.
Drive is Running with this fault.
Type of Drive : ATV6000C638A6360NB4AM5
For troubleshooting , what can we do?
Thanks in Advance.
  • Drives & Motor Control
  • Medium Voltage AC Drives
PriscilaCunha22
Lieutenant JG
Posted: ‎2024-06-07 02:01 AM
Hello @Myazan
Please reach to Country CCC or Schneider Service.
They will need to understand the problem and guide you.
Thank you
PriscilaCunha22
Lieutenant JG
Hello @Myazan
Thank you
