Tesys T Power factor reading
  • Industrial Automation
  • Solutions for Motor Management
  • Tesys T Power factor reading
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Mohamed6
Mohamed6
Cadet
Posted: ‎2024-05-11 01:22 AM
Hi I connected the tesys t with expansion module and it didn't measure the power factor and the frequency, also it didn't measure the active and reactive power.
It gives fault under power factor because it measured by 0.
Are there any solutions for that?
  • Drives & Motor Control
Replies 0
