What is Alternative overloaded method for GetUpdatedAlarmEvents() method
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • What is Alternative overloaded method for GetUpdatedAlarmEvents() method
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa180961_brid
Lieutenant sesa180961_brid Lieutenant
Lieutenant
Posted: ‎2016-10-11 08:57 AM
775
I was using 1.3.xx EwsClient for a program. I updated it to the latest v2.1.83.
My old code was using GetUpdatedAlarmEvents() methods where I was passing the DataRef and LastAlarmRequestId from previous request.
GetUpdatedAlarmEventsResponse alarmEventsPerRequest = ewsClient.GetUpdatedAlarmEvents(0, 1000, alarmStatus.MoreDataRef, types, server.LastAlarmRequestId);
Now that this method is obsolete, could anyone point to the alternative method.
Thanks in advance!
Tags (3)
  • ews
  • getupdatedalarmevents
  • obsolete
sesa180908_brid
Commander
Posted: ‎2016-10-11 09:49 AM
There is an overload for GetUpdatedAlarmEvents with the parameter order changed.
The problem wass really a syntactic thing.  If you weren't using any filters (e.g. priorityTo etc) you still needed to supply all of the null parameters to then supply the lastUpdate parameter.  This was cumbersome to do.  Using the new overload is simply cleaner to use.
You can still use the old method but if you're updating your code, you should just switch over.  I have no plans to remove the old deprecated overload at this time.
sesa180908_brid
Commander
