What is Alternative overloaded method for GetUpdatedAlarmEvents() method
SmartConnector Forum
Send InviteCancel
2016-10-1109:49 AM
There is an overload for GetUpdatedAlarmEvents with the parameter order changed.
The problem wass really a syntactic thing. If you weren't using any filters (e.g. priorityTo etc) you still needed to supply all of the null parameters to then supply the lastUpdate parameter. This was cumbersome to do. Using the new overload is simply cleaner to use.
You can still use the old method but if you're updating your code, you should just switch over. I have no plans to remove the old deprecated overload at this time.
2016-10-1109:49 AM
