EWS Client GetUpdatedAlarmEvents() method LastUpdate Guid mismatch
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • EWS Client GetUpdatedAlarmEvents() method LastUpdate Guid mismatch
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa180961_brid
Lieutenant sesa180961_brid Lieutenant
Lieutenant
Posted: ‎2016-10-19 06:56 AM
991
I poll an AS for alarms using EWS.
I make a GetAlarmEvents() method to get alarm events and I save the LastUpdate guid.
For subsequent requests, I pass the LastUpdate guid to GetUpdatedAlarmEvents() method, to get updated alarm events.
In my case, because the AS was running at 100%, it was cold started. After the cold start, the LastUpdate guid I had saved in my program was not working anymore. It was not returning any alarms.
To fix this, I had to make a GetAlarmEvents() request to get a new LastUpdate guid.
Does an AS restart reset the LastUpdate guid on the AS?
Tags (2)
  • alarmevents
  • ews
sesa180908_brid
Commander
Posted: ‎2016-10-19 07:08 AM
I believe it does but really should be leveraging the "NeedsRefresh" return from GetUpdatedAlarmEvents.  When you receive that (at any time) you will need to restart your workflow again.  By doing this you abstract away the idiosyncrasies of the implementing server (SBO in this case).
Incidentally, there is an AlarmItemReader in the Mongoose.Process namespace which manages this all for you which you should also look at.
sesa180908_brid
Commander
