When installing the Mongoose.Process, I get the following errors:
Restoring packages for C:\Users\SESA44648\source\repos\SmartConnecterWeatherSamples\SmartConnector.FirstWeatherExtension\SmartConnector.FirstWeatherExtension.csproj...
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/mong...
OK https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/mong... 202ms
OK https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/mong... 1689ms
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/newt...
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/syst...
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/ews....
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/sxl....
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/newt... 230ms
OK https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/ews.... 298ms
OK https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/sxl.... 355ms
OK https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/ews.... 472ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/syst... 967ms
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr...
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/owin...
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/weba...
OK https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/ews.... 1160ms
OK https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/mong... 1199ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 197ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/owin... 209ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 281ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 312ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/weba... 356ms
OK https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/ews.... 431ms
OK https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/sxl.... 1367ms
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/nlog...
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/nlog... 190ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/nlog... 195ms
OK https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/mong... 948ms
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/enti...
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/ncro...
GET https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/swas...
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/enti... 213ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 216ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 265ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 310ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 316ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 344ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 366ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 411ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 416ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 465ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 463ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/micr... 505ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/swas... 514ms
NotFound https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/flatcontainer/ncro... 550ms
Installed SxL.Common 2.5.4.18 from https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/index.json with content hash VjpDrSVRyu1x9EhDao94dMhTrUTmULHNCoGlttpJE8IlbD27Rm23f7MKUvruwDQhMIEYrnB0KKDnc/nPO4sxwg==.
Installed Mongoose.Common 2.5.4.18 from https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/index.json with content hash 0woa7MbkEGLvvv+kC9pLDVCuWSwsf/Yt0cYRksLEVLTItVKZ/bbaua+5A4uMJiRH0OY5wq3ZRSvXeXS2vUwBaQ==.
Installed Ews.Common 2.5.4.18 from https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/index.json with content hash 4qoPeVV+gbOFe4/Omjv6lBhEo1AC4H1MO3IC+N74gnBQXVN1wsXAaDOD4h5NDkD5vVu0KuXf2hQ8eWKuIln3GA==.
Installed Ews.Client 2.5.4.18 from https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/index.json with content hash XKHiQoZWjflPsUxh7ZQyHbx3WxwuLkgZUr8OIMWzTes8uHj+SlfaqibbyOlCfFWmZoG5yIsJCdR2fNG45o9IfA==.
Installed Mongoose.Process 2.5.4.18 from https://www.myget.org/F/mongoose/auth/2dd53f27-71f5-455d-b624-c3f71cad5547/api/v3/index.json with content hash oGOLFF9GKRB4K/MQBw4KOWrVn8U/MZXgoqmBHPmC/kOxhLoJ98R8j5UK6j0uUc/BDONlJQ3P1nOv5GNz+fD0Gg==.
NU1102: Unable to find package Newtonsoft.Json with version (>= 12.0.2)
- Found 1 version(s) in Microsoft Visual Studio Offline Packages [ Nearest version: 9.0.1 ]
- Found 0 version(s) in SmartConnector
NU1101: Unable to find package System.ValueTuple. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.AspNet.WebApi.Client. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.AspNet.WebApi.Core. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.Owin. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Owin. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package WebApiThrottle.StrongName. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package EntityFramework. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.AspNet.Cors. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.AspNet.Identity.Core. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.AspNet.Identity.Owin. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.AspNet.WebApi.Owin. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.AspNet.WebApi.OwinSelfHost. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.Owin.Cors. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.Owin.Host.HttpListener. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.Owin.Hosting. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.Owin.Security. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.Owin.Security.Cookies. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Microsoft.Owin.Security.OAuth. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package NCrontab.Signed. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package Swashbuckle.Core. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package NLog.Targets.Syslog. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
NU1101: Unable to find package NLog. No packages exist with this id in source(s): Microsoft Visual Studio Offline Packages, SmartConnector
Time Elapsed: 00:00:06.7463374
========== Finished ==========
