The SmartConnector 2.5.4.18 service failed to start after system restart
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • The SmartConnector 2.5.4.18 service failed to start after system restart
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2022-11-14 07:09 AM
1633
SmartConnector 2.5.4.18 failed to start after system restart. See the exception log below.
It would be nice if this can be fixed in the next version.
Thanks.
Mike
2022-11-14 16:32:30.9046,Error,Service,<no principal>,Error while building type Mongoose.Service.LoggerFilterProvider. See the inner exception for details
1.) new LoggerFilterProvider()
2.) Mongoose.Service.LoggerFilterProvider
3.) Instance of SxL.Common.ILoggerFilterProvider (Mongoose.Service.LoggerFilterProvider)
4.) Container.GetInstance(SxL.Common.ILoggerFilterProvider)
An exception occurred while initializing the database. See the InnerException for details.
The underlying provider failed on Open.
Cannot open database "SmartConnector.Service" requested by the login. The login failed.
Login failed for user 'NT AUTHORITY\SYSTEM'.
at lambda_method(Closure , IBuildSession , IContext )
at StructureMap.Building.BuildPlan.Build(IBuildSession session, IContext context)
at StructureMap.BuildSession.BuildNewInSession(Type pluginType, Instance instance)
at StructureMap.Pipeline.NulloTransientCache.Get(Type pluginType, Instance instance, IBuildSession session)
at StructureMap.BuildSession.ResolveFromLifecycle(Type pluginType, Instance instance)
at StructureMap.SessionCache.GetObject(Type pluginType, Instance instance, ILifecycle lifecycle)
at StructureMap.SessionCache.GetDefault(Type pluginType, IPipelineGraph pipelineGraph)
at StructureMap.Container.GetInstance(Type pluginType)
at StructureMap.Container.GetInstance[T]()
at Mongoose.Service.Mongoose.OnStart(String[] args)
2022-11-14 16:32:30.9381,Info,Service,<no principal>,Exception caught at service level.,
2022-11-14 16:32:30.9381,Error,Service,<no principal>,StructureMap.Building.StructureMapBuildException: Error while building type Mongoose.Service.LoggerFilterProvider. See the inner exception for details
---> System.Data.DataException: An exception occurred while initializing the database. See the InnerException for details. ---> System.Data.Entity.Core.EntityException: The underlying provider failed on Open. ---> System.Data.SqlClient.SqlException: Cannot open database "SmartConnector.Service" requested by the login. The login failed.
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, UInt32 waitForMultipleObjectsTimeout, Boolean allowCreate, Boolean onlyOneCheckConnection, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal oldConnection, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionInternal.TryOpenConnectionInternal(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
at System.Data.ProviderBase.DbConnectionClosed.TryOpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
at System.Data.SqlClient.SqlConnection.TryOpenInner(TaskCompletionSource`1 retry)
at System.Data.SqlClient.SqlConnection.TryOpen(TaskCompletionSource`1 retry)
at System.Data.SqlClient.SqlConnection.Open()
at System.Data.Entity.Infrastructure.Interception.DbConnectionDispatcher.<>c.<Open>b__13_0(DbConnection t, DbConnectionInterceptionContext c)
at System.Data.Entity.Infrastructure.Interception.InternalDispatcher`1.Dispatch[TTarget,TInterceptionContext](TTarget target, Action`2 operation, TInterceptionContext interceptionContext, Action`3 executing, Action`3 executed)
at System.Data.Entity.Infrastructure.Interception.DbConnectionDispatcher.Open(DbConnection connection, DbInterceptionContext interceptionContext)
at System.Data.Entity.Core.EntityClient.EntityConnection.<Open>b__55_0()
at System.Data.Entity.Infrastructure.DbExecutionStrategy.<>c__DisplayClass17_0.<Execute>b__0()
at System.Data.Entity.Infrastructure.DbExecutionStrategy.Execute[TResult](Func`1 operation)
at System.Data.Entity.Infrastructure.DbExecutionStrategy.Execute(Action operation)
at System.Data.Entity.Core.EntityClient.EntityConnection.Open()
--- End of inner exception stack trace ---
at System.Data.Entity.Core.Objects.ObjectContext.EnsureConnection(Boolean shouldMonitorTransactions)
at System.Data.Entity.Core.Objects.ObjectContext.ExecuteInTransaction[T](Func`1 func, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction, Boolean releaseConnectionOnSuccess)
at System.Data.Entity.Core.Objects.ObjectQuery`1.<>c__DisplayClass41_0.<GetResults>b__0()
at System.Data.Entity.Core.Objects.ObjectQuery`1.GetResults(Nullable`1 forMergeOption)
at System.Data.Entity.Core.Objects.ObjectQuery`1.<System.Collections.Generic.IEnumerable<T>.GetEnumerator>b__31_0()
at System.Data.Entity.Internal.LazyEnumerator`1.MoveNext()
at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable`1 source)
at System.Data.Entity.Core.Objects.ELinq.ObjectQueryProvider.<>c__14`1.<GetElementFunction>b__14_1(IEnumerable`1 sequence)
at System.Data.Entity.Core.Objects.ELinq.ObjectQueryProvider.ExecuteSingle[TResult](IEnumerable`1 query, Expression queryRoot)
at System.Data.Entity.Core.Objects.ELinq.ObjectQueryProvider.System.Linq.IQueryProvider.Execute[TResult](Expression expression)
at System.Data.Entity.Internal.Linq.DbQueryProvider.Execute[TResult](Expression expression)
at System.Linq.Queryable.FirstOrDefault[TSource](IQueryable`1 source)
at System.Data.Entity.Internal.EdmMetadataRepository.QueryForModelHash(Func`2 createContext)
at System.Data.Entity.Internal.InternalContext.QueryForModelHash()
at System.Data.Entity.Internal.ModelCompatibilityChecker.CompatibleWithModel(InternalContext internalContext, ModelHashCalculator modelHashCalculator, Boolean throwIfNoMetadata, DatabaseExistenceState existenceState)
at System.Data.Entity.Internal.InternalContext.CompatibleWithModel(Boolean throwIfNoMetadata, DatabaseExistenceState existenceState)
at System.Data.Entity.CreateDatabaseIfNotExists`1.InitializeDatabase(TContext context)
at System.Data.Entity.Internal.InternalContext.<>c__DisplayClass66_0`1.<CreateInitializationAction>b__0()
at System.Data.Entity.Internal.InternalContext.PerformInitializationAction(Action action)
at System.Data.Entity.Internal.InternalContext.PerformDatabaseInitialization()
at System.Data.Entity.Internal.LazyInternalContext.<>c.<InitializeDatabase>b__58_0(InternalContext c)
at System.Data.Entity.Internal.RetryAction`1.PerformAction(TInput input)
at System.Data.Entity.Internal.LazyInternalContext.InitializeDatabaseAction(Action`1 action)
at System.Data.Entity.Internal.LazyInternalContext.InitializeDatabase()
at System.Data.Entity.Internal.InternalContext.Initialize()
at System.Data.Entity.Internal.InternalContext.ForceOSpaceLoadingForKnownEntityTypes()
at System.Data.Entity.DbContext.System.Data.Entity.Infrastructure.IObjectContextAdapter.get_ObjectContext()
at Mongoose.Service.Data.MongooseDbContext.WireUpEncryption()
at Mongoose.Service.Data.MongooseDbContext..ctor(Boolean automaticDecryption)
at Mongoose.Service.LoggerFilterProvider.Refresh()
at System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state)
--- End of stack trace from previous location where exception was thrown ---
at System.ServiceProcess.ServiceBase.Run(ServiceBase[] services)
at Mongoose.Service.Program.Main(),
MaximeLaudren
Lieutenant MaximeLaudren Lieutenant
Lieutenant
Posted: ‎2023-03-17 03:22 PM
Hi Mike,
The error indicate the SC cannot log to the database.
Check that the SQL server is running on the machine.
Max
Daniel_Cerone
Lieutenant JG Daniel_Cerone Lieutenant JG
Lieutenant JG
Posted: ‎2023-07-25 05:47 AM
if sql is running and you can connect to management studio, see if your db is in suspect mode (or offline- just online it).  there are scripts that can take it out of that mode (usually due to data issues), but you may lose some db data in the process.
try connecting to the db directly via odbc.
/dcer
