Cant setup smart connector with EBO
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Cant setup smart connector with EBO
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
LuxuryWaffles
Crewman LuxuryWaffles
Crewman
Posted: ‎2023-04-06 11:01 PM
2397
I would like to use smart connector to expose API endpoints such that I can read and write data to EBO from 3rd party APIs.
Smart connector have been setup at localhost:8082 which is also the same server as EBO.
I am unsure of the concept of EWS so I tried various ways which all didnt work for me.
First way is to connect smart connector endpoint to EBO's EWS:
1) Enable EWS Server: Server -> EcoStruxure Web Services -> Server Configuration -> Enable EWS Server
2) Add User -> Server -> Domains -> Local -> Users -> Add SmartUser with Administrator Group
3) Add new Endpoint in SmartConnector -> RestExtensions.SoapEwsRestProvider -> Stuck at server Address
I am unsure what would be the server address of the EBO's EWS as it isnt stated anywhere after toggling
I then tried to connect EBO to SmartConnector's EWS instead:
1) Create EWS Server: http://localhost:51350/EcoStruxure/DataExchange
2) Add new Endpoint in SmartConnector -> SoapEwsRestProvider -> EWS Server from step 1
3) In EBO create EWS Interface to EWS Server from step 1 (Started with Version 1.2 and not offline)
4) Open swagger url from step 2
5) Tried to login to swagger with user from EBO and SmartConnector, invalid user and password
I am really lost right now on just setting up the connection, would like to get some help from the experts here!
Replies 7
Erwin-vd-Zwart
Janeway
Posted: ‎2023-04-06 11:21 PM . Last Modified: ‎2023-04-06 11:24 PM
2390
EWS settings looks fine, the server address in the endpoint should be like this: http://localhost:81/EcoStruxure/DataExchange where my ES is running on the same machine on port 81 for HTTP
LuxuryWaffles
Crewman
Posted: ‎2023-04-06 11:25 PM
It seems the user created in EBO is the issue, using the default admin, I am able to connect.
Weird that both admin and my SmartUser have the exact same settings
Erwin-vd-Zwart
Janeway
Posted: ‎2023-04-06 11:28 PM
2381
I have seen in the past some issues with special chars in the PWD, especially "@" but not sure this is still the case, can you try to change the PWD
LuxuryWaffles
Crewman
Posted: ‎2023-04-06 11:31 PM
tried changing to same password as the admin,  same issue,
Server EWS Version turns to ? the moment it is saved
Erwin-vd-Zwart
Janeway
Posted: ‎2023-04-06 11:38 PM . Last Modified: ‎2023-04-06 11:40 PM
2377
Please check the permissions of the new user, must be in that direction..
If the admin account can connect / is working than the SC endpoint is set correct, the EWS settings are correct, so only thing that could block it are the user settings like PWD and permissions..
Edit: is the new user member of the local domain? or customer domain? as far as ik know it must be a local domain member..
LuxuryWaffles
Crewman
Posted: ‎2023-04-07 12:12 AM . Last Modified: ‎2023-04-07 12:12 AM
the user is in local domain, able to login and all too,
I guess i will just move on to writing the smartconnector extension first with admin
Thanks a bunch for your help though!
Daniel_Cerone
Lieutenant JG Daniel_Cerone Lieutenant JG
Lieutenant JG
Posted: ‎2023-07-25 05:39 AM . Last Modified: ‎2023-07-25 05:40 AM
search for the smartconnector success kit on this forum.  it may help you figure out your user issue.
/dcer
