SmartConnector Upgrade from v1.3.45 to v2.4.10 or current version
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector Upgrade from v1.3.45 to v2.4.10 or current version
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa180961_brid
Lieutenant sesa180961_brid Lieutenant
Lieutenant
Posted: ‎2019-01-09 09:05 AM . Last Modified: ‎2022-04-28 06:55 AM
880
One of our customers is looking to upgrade from v1.3.45 to v2.4.10 or the current version.
Is there a guide to follow for the upgrade process?
Tags (2)
  • smartconnector upgrade
  • v1.3.45
JeffBowman
Sisko
Posted: ‎2019-01-09 09:11 AM
Hello!
That is quite the old version of Smart Connector!
With that said, there really is no guide, but see below for a summary of what you will need to do:
  1. For each Extension that the customer is using, you will need to get an updated .dll from the developer of the extension for 2.4.10. You will then need to work with those developers if anything on the extension has changed over time to get it working again on your site.
  2. For each Extension and the Framework itself, you will need to get an updated license.
  3. As far as the "install" itself, you should in theory be able to do a straight upgrade.. but I personally havent tested it and upgrade from a version that old.
-Jeff
JeffBowman
Sisko
Hello!
-Jeff
