SmartConnector 2.4 - EBO 1.9 - Swagger UI "The User Name or Password were incorrect.
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector 2.4 - EBO 1.9 - Swagger UI "The User Name or Password were incorrect.
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
DimitriY
DimitriY Schneider Alumni (Retired)
Posted: ‎2019-01-09 01:07 PM
2405
I can't manage to get the authentication token from the swagger ui (always get the "The User Name or Password were incorrect." error message).
I guess the issue come from the endpoint http configuration rather than to the login/pwd.
I'm using SmartConnector version 2.4.8, and EBO 1.8 or 1.9.
I've tried with both SBO and SOAP Rest providers.
Any suggestions ?
JeffBowman
Sisko
Posted: ‎2019-01-10 05:53 AM
2394
Try to set your 'Server Domain' to 'Local'. This should be the same domain you use to log into EBO from workstation.
-Jeff
Replies 5
DimitriY
Posted: ‎2019-01-10 05:16 AM
2400
I managed to get it work for "SOAP REST Provider" (not yet for "SBO REST Provider")
JeffBowman
Sisko
Posted: ‎2019-01-10 05:18 AM
2399
Can you show what we are using for your SBO REST Gateway configuration?
-Jeff
DimitriY
Posted: ‎2019-01-10 05:30 AM
2397
Attached the 2 configurations :
- SOAP_REST_Provider_cfg.PNG : working !
- SBO_REST_Provider_cfg.PNG : not yet working...
JeffBowman
Sisko
2395
-Jeff
DimitriY
Posted: ‎2019-01-10 06:03 AM
It works like that !!
Thank you very much Jeff !
Dimitri
